Airontario
Add-on Textures
Tue Mar 12, 2002 7:59 am
can anyone tell me how to use the addon textures for like 737 777 and stuff. i see all the pictures but i cant seem to work the textures any help?
crank
RE: Add-on Textures
Tue Mar 12, 2002 8:31 am
If you want to add textures to the 737 for example you'll have to create another texture folder. If you are using FS2002, there will already be 3 texture folders, you'll have to add another one with the BMP files in it.
In the 737 folder, there is already 3 texture folders called texture, texture.1 and texture.2. You'll have to create a folder called texture.3 or anything else as long as the texture word is there. You could call it for example texture.United.
This also means that you'll have to add some lines in the aircraft.cfg:
[fltsim.3] <-- means that this is the 4th 737
title=Boeing 737-400
sim=Boeing737-400
model=
panel=
sound=
texture=3 <-- link to the texture folder named texture.3, where you put the texture files
kb_checklists=Boeing737-400_check
kb_reference=Boeing737-400_ref
atc_id=N700MS
atc_airline=United
atc_flight_number=1123
ui_manufacturer=Boeing
ui_type=737-400
ui_variation=Unites Airlines
Hope this helps
Dash8King
RE: Add-on Textures
Tue Mar 12, 2002 8:35 am
Yes any other questions might be answered with the topic I started "How to open the .CFG file" or if that isn't right just do a search with my author name lots of useful help!
Airontario
RE: Add-on Textures
Tue Mar 12, 2002 8:38 am
k thanks alot guys
Users browsing this forum: No registered users and 19 guests
