Blackened
ILS APR-hold Autopilot In FS2002?
Thu Apr 25, 2002 12:22 am
When I manually fly the aircraft to the glideslope or even on the glideslope like during a usual manual landing (which I always do) the autopilot does not work at all when I choose "APR-hold". The autopilot doesn't do anything (sometimes one single aileron input) and the aircraft will leave the glideslope pretty soon.
How can you perform an autopilot ILS landing? It used to work in FS98 so I know what I'm talking about but it doesn't work in FS2002. Does it have to do with the angle you hit the glideslope? Why doesn't the AP simply hold the glideslope if I'm already on the right way?
Bring it back, bring it back, bring it back
BWIrwy4
RE: ILS APR-hold Autopilot In FS2002?
Thu Apr 25, 2002 12:36 am
Try landing without the autopilot. It's MUCH more fun that way.
Blackened
Thu Apr 25, 2002 12:44 am
That's what I've always done. Just wanna see how the AP works in this case.
Landing with the AP isn't flight sim, is it? VFR in 15 kts crosswind, OK. Holding the ILS by yourself with help of the panel, OK.
jwenting
Thu Apr 25, 2002 12:50 am
engage not only the APR hold but also the autopilot itself. Just pressing APR hold with the AP disabled will not turn on the AP.
Also make sure you have an ILS selected and active and the Nav/GPS switch set to Nav.
Approach the localiser within 30 degrees and from slightly below.
I wish I were flying
cosync
Thu Apr 25, 2002 1:10 am
hehe jwenting.
me and u should fly on the net some time. I love ils approaches Smile i just hate it when u have to quickly get another frequencie cause u thought the active runway for the airport was on the other side Sad stupid microsoft.
w_a_s_p_i_e
Thu Apr 25, 2002 4:48 am
Yea, like Jwenting said, make sure you have tuned your OBS in and the nav. frequency is correct. Then turn on APR hold and then click on AP.
That should do it!!
Blackened
Fri Apr 26, 2002 9:19 pm
Oh my god, I'm not stupid and I've spent hundreds of hours with MSFS since I had a black and white version of it when was in 1st grade.
I didn't forget any of the things you've mentioned.
KALB
Sat Apr 27, 2002 1:03 am
Are you maintaining enough airspeed, so as not to drift below the glideslope once the autopilot and APR funtions are engaged? I find the ILS works just as well in FS2K2 as in the previous versions.
jcxp15
Sun Apr 28, 2002 1:32 pm
The APR button is fiesty on FS2002. Before turning it on, make sure that you're exaclty on the glideslope, and then turn it on. Don't have the APR get you on the ILS, b/c it won't work (which might be what's happening in your case)./
Sun Apr 28, 2002 1:59 pm
I have only been playing with FS2002 for a couple days, but I have been successfull in getting it intercept the glideslope with no problem. The only difference between the APR mode in 2002 and the APR mode in earlier versions is that it will not intercept the glideslope if you are above it. If you are below the glide slope it will intercept without a problem. MS said they did it that way on purspose to make it more realistic.
