cramos
What Are Your Disply Settings In FS2002?
Wed Jun 12, 2002 5:15 am
I just wanted to know if anyone had a similar system to mine. I made some upgrades but I want to get the best looking simulation with good performance. I have the following:
400MHz PII
10GB Hard Drive
384 MB RAM
64 MB GeForce 2 Ti Video card
What display settings are you using? What display settings make a difference? Thanks for your help.
crank
RE: What Are Your Disply Settings In FS2002?
Wed Jun 12, 2002 6:52 am
My system:
AMD-K6-2 500 mhz
8GB Hard Drive
192 MB RAM
Nvidia TNT2 Pro 16 MB (soon to be Geforce 3 Ti 500)
Windows XP Pro
FS2002 Display settings:
/Scenery:
-Texture Quality: Medium
-Terrain Mesh Complexity: 50
-Terrain Texture Size: Medium
-Autogen Density: Normal
-Scenery Complexity: Normal
-Dynamic Complexity: Normal (ATC: 50%)
-Effects Detail: Low
-Maximum Visibility: 60 NM
-Water Effects: none
-Cloud Density: 45
/Aircraft:
-Aircraft Texture Size: Medium
-Virtual Cockpit Gauge Quality: Low
-Reflections: Unchecked
-Aircraft Cast Shadows: Unchecked
-Landing Lights: Checked
-Resize panel with main window: Checked
/Hardware:
-Target Frame Rate: 15
-Lights: 3
-Bilinear Filtering: Checked
Everything else unchecked except for MIP Mapping
Note that I disable AI traffic in dense areas. The frame rates are around 15 most of the time.
cramos
Wed Jun 12, 2002 4:25 pm
Thanks Crank, it's good to hear from a person who has a similar processor and hard drive. 15 fps is a good and smooth simulation? I have it at 25 for now, but when clouds come in, they tend to drop. So you are satisfied with the overall performance? I mean when you are in the clouds or look out the side, the ground looks good enough?
