Jaspike
Taxiing Help Needed!
Sun Jul 07, 2002 11:35 pm
Can someone tell me how to taxi properly in FS2002?
I start to taxi, but the plane usually goes too fast and goes over runways, through building, over grass etc. How can I taxi?!
Please help! Big thumbs up
Josh
 Smile/happy/getting dizzy
Mr.BA
RE: Taxiing Help Needed!
Sun Jul 07, 2002 11:51 pm
Taxi only at a maimum of 30 knots. Turn at around 8 knots. Use your rudder to turn, never the ailerons.
Boeing747 万岁!
jwenting
Mon Jul 08, 2002 2:21 am
I'd call 30 knots a bit high. 15-20 is better, when going over 20 throttle back a bit.
some planes need a lot of power to get moving. As soon as it moves, you can throttle back to almost idle.
For the rest, practice makes perfect and remember that each aircraft behaves differently.
I wish I were flying
Mon Jul 08, 2002 4:16 am
Also, you cannot taxi using the mouse. The keyboard is virtually impossible, IMO, you have to use a joystick.
sunbird
Mon Jul 08, 2002 4:33 am
if your using a turbo prop aircraft reduce your prop pitch.
concorde1518
Mon Jul 08, 2002 11:09 am
usually, you don't want to get over 20, unless you fly for Southwest  Big grin
 Smile
crank
Mon Jul 08, 2002 11:31 am
Here's how I do it:
to begin the taxi I push the throttle to about 50% and as soon as the plane starts rolling I decrease the thrust nearly to the minimum to maintain a speed of 12-15 knots, to turn (90°) I decrease the speed to 5 knots and as soon as I start turning I add a little bit of power just to keep rolling.
Hope this helps
Gib
Mon Jul 08, 2002 1:10 pm
Use the brake, rudder with applicable power on your turns. This will help in that dep't. Also, you might want to get a tower view now and then to judge distances. ??
I'm getting old, but don't all FS's from '97 on, pretty much taxi/turn the same way. Is this your 1st FS?
Agree with Jwenting re: different a/c, also.
CD
9V-SVE
Mon Jul 08, 2002 1:44 pm
I use the keyboard to taxi, its not too hard. Sometimes I put max throttle for 1 second that then immediatly hit F1!  Big thumbs up
Jaspike
Tue Jul 09, 2002 12:59 am
Gib: This is my first FS Big thumbs up
Thanks for your help everyone, I can do it better now Smile/happy/getting dizzy
Josh
crank
Tue Jul 09, 2002 3:44 am
I forgot to add that I use the keyboard to turn on the ground, it also controls the rudder in my case
EGNV
Sun Jul 14, 2002 4:28 am
One of the most useful feautures in my opinion is the differential braking. Try hitting F11 on a left turn and F12 on a right turn.
EGNV.
concorde1518
Mon Jul 15, 2002 10:23 am
Differential Braking is good, but usually not recommended of your aircraft has bogey main gear. If you are flying a three or four engined aircraft, differential thrust is good. On my CH yoke, if I'm flying a twinjet, I'll assign the prop lever to be the #2 engine throttle, and with tri-jets, Ill assign the mixture axis to the third engine (I'm just kinda screwed if I fly a 4 engined jet, I have to control all 4 with 1 lever) so I can independently control each engine.
 Smile
