deltadude8
3rd Party Software? Er Message In FS2K Need Help
Fri Aug 09, 2002 12:04 pm
Sometimes, not all the time, but sometimes, after I download aircraft or stuff like that and load it in Select Aircraft, I get some kind of a message about 3rd party software...
Does anyone else get this error message? What in God's name does it mean, and how can I fix it? It won't let me fly the plane that it comes up on when I select it.
Thanks for the help,
Deltadude8
n521na
RE: 3rd Party Software? Er Message In FS2K Need Help
Fri Aug 09, 2002 5:17 pm
Just ignore it, the aircraft will still show up when you fly it.
deltadude8
Sat Aug 10, 2002 1:09 pm
I tried clicking on a Northwest Airbus jet and the message came up but I click okay or whatever and it didn't load the plane?
So now i am back to square one...Thanks for trying to help and it is not only this Northworst jet that the message comes up...It comes up on many different ones.
Open to suggestions
crank
Sat Aug 10, 2002 1:48 pm
Do you have FS2K or FS2K2 ?
deltadude8
Sun Aug 11, 2002 12:28 am
I own Microsoft Flight Simulator 2002 Professional
n521na
Sun Aug 11, 2002 3:08 am
Yea the plane wont show up in the preview box thing. It will probably be a cessna but in the game it will be the correct plane.
crank
Sun Aug 11, 2002 4:58 am
OK Deltadude I think I have the solution. you are probably using a panel that requires Fssound.dll, which you probably already have in your modules folder.
Try adding these lines to your FS2002.cfg (found in the main FS2002 folder):
[OldModules]
FSSound.dll=1
Tell me if it works.
deltadude8
Sun Aug 11, 2002 11:02 am
Where do I add this?
In the FS2002 folder in the notepad file names FS2002?
Please let me know.
thanks so much,
Deltadude8
crank
Sun Aug 11, 2002 11:08 am
In your FS2002 main folder, there's a file named FS2002.cfg, you open it with notepad and add the lines I stated above.
deltadude8
Sun Aug 11, 2002 11:33 am
Alright, Thanks so much I will let you konw what happens.
Deltadude8@aol.com
deltadude8
Sun Aug 11, 2002 11:57 am
No this didn't help... I added the lines at the bottom of the cfg file but the error still comes up.
It says something about the 3rd party software cant be loaded so it will be disabled.
Then it states the file name...Which is...Like Program Files/Microsoft Games/FS2002/Aircraft/_______
______=the name of the file about the plane.
Any more suggestions welcome.
Deltadude8
