flyboy36y
FS2002: Any Way To Open Doors Other Than Main?
Fri Aug 23, 2002 4:29 pm
Other than the main door opening... can the other aircraft doors be oppened? How?
l'espace180
RE: FS2002: Any Way To Open Doors Other Than Main?
Fri Aug 23, 2002 8:05 pm
You can open other doors or luggage doors by quickly pressing 1 or 2 (not on the number pad, but with the numbers above the letter pad).
l'espace180
Fri Aug 23, 2002 8:06 pm
I forgot something : quickly press 2 after you pressed shift + E
dc-10 levo
Sat Aug 24, 2002 1:34 am
That doesn't work for me.  Sad
DC-10
Jaspike
Sat Aug 24, 2002 4:09 am
I'm still quite new to FS2002... How do you open the main door?
Josh
 Smile/happy/getting dizzy
wietse
Sat Aug 24, 2002 4:13 am
Shift E.
If there arent doors opening by using Shift E + 2, then the ac doesn't support it...
Wietse de Graaf
dc-10 levo
Sat Aug 24, 2002 4:24 am
Do the microsoft planes support it?
DC-10
l'espace180
Sat Aug 24, 2002 5:53 am
Yes Levo, the microsoft a/c support it, as well as a few freeware a/c. Some freeware have their door opened when you deploy spoilers on the ground, or when engines are shut down.
If it doesn't work when you press Shift E +2, just continue pressing. It doesn't always work at first time.
dc-10 levo
Sat Aug 24, 2002 7:06 pm
When I press Shift E+2 the radio stack opens up?
I'll keep pressing anyway.
DC-10
wietse
Sat Aug 24, 2002 8:03 pm
Shift + E, release all keys, and quickly press 2. There must be some time between pressing the shift e and the 2
Wietse
Wietse de Graaf
dc-10 levo
Sun Aug 25, 2002 8:39 pm
Yep, done it.
Thanks everyone.
DC-10
flyboy36y
Tue Aug 27, 2002 10:16 am
OK,
I used to think that all the doors can be oppened. They cannot. The cargo door on the belly oppens when you press "Shift 2"
jgore
Mon Sep 02, 2002 9:32 am
why don't you guys check the keyboard assigment configuration ? i guess if there's not any detailed file, it might be inside FS2002's keyboard configuration screen.
Jgore  Smile
Sinlock
Mon Sep 02, 2002 11:10 am
The 747 and both Caravan's. are the only standard planes in 02 that have more than one "door" that open
9V-SVA
Mon Sep 02, 2002 11:58 am
Sinlock, wrong. The Boeing 737-400 has main and cargo doors that open. Same goes for the Project AI A320s.
9V-SVA
9V-SVA | B772ER
Users browsing this forum: Google Adsense [Bot] and 6 guests
