cramos
Which Default Aircrafut (fs2002) Do You Use Most?
Sun Aug 25, 2002 6:43 pm
Just wondering what everyone's first three choices are when flying the default aircraft in fs2002. If you can, tell me why you like the aircraft, thanks.
RE: Which Default Aircrafut (fs2002) Do You Use Most?
Mon Aug 26, 2002 10:24 am
I like all aircraft in Landmark colors, I think the 737 looks really great in them. I like flying the green/tan C182, the Learjet, and the Mooney. My favorite light cross country airplane is the Baron. Big grin
Tbird
Mon Aug 26, 2002 10:42 am
Greetings:
Does it count that I changed the texture? I use the 737 in Delta's colors the most from the default aircraft.
Tom
Mon Aug 26, 2002 11:24 am
I think the only non-stock airplane that have is a repainted King-air, and I'm probably going to switch it back. But then again, I'm probably going to re-install my FFG Learjet 35s.
To answer the question, the default airplane that I spend the most time with is the Learjet 45. I like the Mooney (IFR panel), and the Cessna 182 S. And the Baron is another one of my favorites.
I don't spend much time with the airliners. Mostly I just like to see them as AI traffic. But when I do fly an airliner, it's almost invariably the Orbit 737. I also have been known to fly the Emerald Harbor Caravan.
It'd probably be easier to phrase it in terms of the default aircraft that I don't fly very often. And the answer to that would be:
The 747 and 777
The Schwiezer (which I intend to spend more time with later)
The Sopwith
The Corsair
The Caravan floatplane
'Speed
dragon-wings
Mon Aug 26, 2002 12:57 pm
The default aircraft I fly the most is the Learjet 45.
Don't give up don't ever give up - Jim Valvano
