deltaalpha
How To Remove Aircraft?
Wed Oct 30, 2002 1:56 am
How do you remove aircraft that you have installed that you dont fly anymore?
I have many many that I dont fly and I dont want to damage my system so how do I safely remove them?
Delta Alpha
Common sense is not all that common
United_fan
RE: How To Remove Aircraft?
Wed Oct 30, 2002 2:40 am
You right click on the START icon,go into C drive , Program Files , Microsoft Games , FS2002 , aircraft , then right click on the one you want to delete, then click delete. It sends it to the recycle bin.
Champagne For My Real Friends,and Real Pain For My Sham Friends
Sinlock
Wed Oct 30, 2002 3:44 pm
I just looked at my "/aircraft" folder. Its 2.43 Gig!!!!!!! And I clean it out all the time.
flyboy36y
Wed Oct 30, 2002 6:29 pm
Maybe it's large because you have re-copied original sound/panel files.
Instead of actualy using the original (737 as an example) sound file and recopying all the sounds to the new plane, you can have an alias sound.cgf that simply access the 737's sound an does not need a copy of the sounds in that folder. email me if you need more info...
deltaalpha
Thu Oct 31, 2002 1:28 am
With well over a hundred aircraft in the data base the file MUST be trimmed down. I carefully last night went through all the aircraft I have deleting those that I never fly or disliked or were not in my AI. Much more space now.
Delta Alpha
ronen
Thu Oct 31, 2002 5:52 pm
157 active AI aircraft in my data base . I'm adding about 8-12 a week. What would I do without air-shuffler.
