cramos
Who Uses The Virtual Cockpit In FS2002
Mon Dec 02, 2002 6:11 am
Does anyone use the Virtual Cockpit in FS2002? How is it using it? Do you get a realistic view, is it hard to control the aircraft? How do you know if you're properly aligned with the centerline. I've been wanting to try it, so maybe I'll experiment with it, but I just wanted to know what your experiences are with it and if you have any advice, thanks.
RE: Who Uses The Virtual Cockpit In FS2002
Mon Dec 02, 2002 6:25 am
I tend not to use the virtual cockpit view because my computer can't handle it Sad. So I just use the normal 2D view Smile.
EAC_732
deltaalpha
Mon Dec 02, 2002 7:41 am
I use it often I dont have any problems with it and while manuvering I find it usefull.
delta alpha
Common sense is not all that common
sushka
Mon Dec 02, 2002 10:00 am
It makes it look more realistic but I still prefer the old way.
go and try it for yourself  Smile
Pershoyu Spravoyu Litaki!
xtristarx
Fri Dec 13, 2002 9:29 pm
only for helicopter flights, or some sightseeing flights with the little birds...
