cramos
MS King Air 350 Advancing On Its Own?
Mon Dec 02, 2002 6:13 am
Does anyone have a problem with the default King Air in fs2002 advancing on is own? I have an MS Forcefeedback joystick, and when I let go of the breaks, at idle, the aircraft goes forward. Is this the way a King Air is in real life? Thanks ahead of time for your comments.
sushka
RE: MS King Air 350 Advancing On Its Own?
Mon Dec 02, 2002 9:55 am
I have a different joystick and it happens to me also.
Its a great plane but I have to remember to keep the brakes on when im not moving.
Pershoyu Spravoyu Litaki!
Accidentally
Mon Dec 02, 2002 11:58 am
Bring the condition levers down to 'low idle', like in the real thing.
Indianapolis, IN
Mon Dec 02, 2002 12:37 pm
I've noticed that too, and I was just going to say exactly what Accidently said. When the condition levers are at high idle, it wants to move. At low idle, it taxis like other airplanes.
'Speed
jwenting
Mon Dec 02, 2002 5:16 pm
It's quite simple. Props on a turboprop aircraft (maybe not on all) generate more power than is needed to overcome static inertia when running at full pitch.
Reducing pitch to a lower level reduces that power output and will allow the aircraft to stop accellerating. Taxi using either proppitch and/or differential braking.
I wish I were flying
cramos
Mon Dec 02, 2002 6:14 pm
Thanks everyone  Big thumbs up I'll try those suggestions out.
Sinlock
Wed Dec 11, 2002 10:54 am
It is a glitch in the 350's .MDL file. It has a strange way of reading the throttle of the joystick.
If you pull back on the throttle and look at your guages, and then press F1 you will see the turbine spin down a little more.
