Cadet985
Radio Frequencies
Thu Dec 26, 2002 12:52 am
Does anyone know what the radio frequencies for Philadelphia International Airport (PHL) are? The only one I know is their control tower (118.500).
Thanks in advance,
RE: Radio Frequencies
Fri Dec 27, 2002 1:26 am
From http://www.airnav.com
UNICOM: 122.95
ATIS: 133.4
WX ASOS: PHONE 215-492-9617
PHILADELPHIA GROUND: 121.9 348.6 121.65
PHILADELPHIA TOWER: 118.5(RYS 09L/27R 17/35 08/26) 135.1(RY 09R/27L) 327.05
PHILADELPHIA APPROACH: 123.8(001-089 AT OR BELOW 5000 FT) 126.6(090-269 ABOVE 5000 FT) 126.85(270-360 AT OR BELOW 5000 FT) 127.35(090-269 AT OR BELOW 5000 FT) 128.4(270-089 ABOVE 5000 FT) 263.125(090-269) 263.125(270-360) 273.575(270-089 ABOVE 5000 FT) 291.7(001-089) 317.55(090-269 ABOVE 5000 FT)
PHILADELPHIA DEPARTURE: 119.75(090-269) 124.35(270-089) 269.25(090-269) 320.1(270-089)
CLEARANCE DELIVERY: 118.85 348.6
AT OR BLO 5000 FT.: 263.125(090-269) 263.125(270-360) 291.7(001-089)
CLASS B: 118.35(SW 6000 FT & BLO) 119.75(SE RY 09 ACTIVE 10000 FT & BL 119.75(SE RY 27 ACTIVE 8500-10000 FT 123.8(NE RY 27 ACTIVE 5000 FT & BLO) 124.35(NE RY 09 ACTIVE 10000 FT & BL 124.35(NW 8000-10000 FT) 124.35(W RY 09 ACTIVE 8500-10000 FT) 124.35(W RY 27 ACTIVE 10000 FT & BLO 126.6(SE RY 27 ACTIVE 5500-8000 FT) 126.6(SW 6500-10000 FT) 126.85(NW 7500 FT & BLO) 127.35(S 5000 FT & BLO) 127.35(SE RY 27 ACTIVE 5000 FT & BLO 128.4(N NE 6500-7500 FT) 128.4(NE RY 27 ACTIVE 5500 FT & ABV) 128.4(W RY 09 ACTIVE 8000 FT & BLO) 263.125(NW 7500 FT & BLO) 263.125(S 5000 FT & BLO) 263.125(SE RY 27 ACTIVE 5000 FT & BL 269.25(SE RY 09 ACTIVE 10000 FT & BL 269.25(SE RY 27 ACTIVE 8500-10000 FT 273.575(N NE 6500-7500) 273.575(NE RY 27 ACTIVE 5500 FT & AB 273.575(W RY 09 ACTIVE 8000 FT & BLO 291.7(NE RY 27 ACTIVE 5000 FT & BLO) 317.55(SE RY 27 ACTIVE 5500-8000 FT) 317.55(SW 6500-10000 FT) 319.15(NE RY 09 ACTIVE 10000 FT & BL 320.1(NW 8000-10000 FT) 320.1(W RY 09 ACTIVE 8500-10000 FT) 320.1(W RY 27 ACTIVE 10000 FT & BLO) 323.1(SW 6000 FT & BLO)
EMERG: 121.5 243.0
FINAL APCH: 125.4
IC: 124.35 317.55(090-269 ABOVE 5000 FT) 319.15
ILS PRM RY 26 IC: 123.6
ILS PRM RY 27L IC: 120.425
WX ASOS at PNE (16 nm NE): PHONE 215-677-0146
WX ASOS at VAY (19 nm E): 119.325 (609-267-1176)
goboeing
Fri Dec 27, 2002 6:55 am
Living in the area, I can break that down a little to eliminate all of that .55(SE RY 27 ACTIVE 5500-8000 FT) stuff.
South fix departures: 119.75
North fix departures: 124.35
27L tower: 135.1 (departing rwy for jet 90% of time)
27R/26/ 17/35 tower: 118.5 (27R jet landings, 26 prop landings, 17/35 prop ops)
Final approach during peak arrival times: 125.4
North approach (BUNTS, MAZIE arrivals): 128.4
South approach (CEDAR LAKE, DUPONT arrivals): 126.6
Clearance: 118.85
Ground: 121.9 mostly
Ramp: OH MY GOD I FORGET THE RAMP FREQUENCY! I haven't been home in several months. I'll find it. It's interesting to hear if you're right across at Island Avenue.
Nick
