FrequentFlyKid
Downloading Aircraft For FS2002
Tue Dec 31, 2002 4:20 am
I successfully downloaded a plane from my virtual airline, however when I try to select it from the drop-down menu it tells me that it is not enabled. Do I need to install some sort of kit or what not? Please help.....
wilax
RE: Downloading Aircraft For FS2002
Tue Dec 31, 2002 9:41 am
Well, I've never had fs2k2 tell me that a plane was not enabled, but I have had them not work or even show up on the a/c lists.
Sometimes, certain aircraft arrive in your computer several sub-folders deep, and you must make sure you select the last subfolder with the model, panel, texture, etc inside it and move only that folder into the fs2k2aircraft folder.
Also, sometimes I accidentally download the wrong fs edition for the a/c and it will partly show up in the simulator.
If you are beyond all this, I can't help ya much...
Notar520AC
Wed Jan 01, 2003 10:37 am
FrequentFlyKid- did you unzip the files to the proper directory or just leave the zipped folders laying where you downloaded them to?
Let me know if you need any help.
FalconJet4820d@cox.net
BMW - The Ultimate Driving Machine
