gregjet
Climb Problems
Sat Jan 18, 2003 12:02 pm
When I am climbing around fl240 I start to stall what's the problem is it the VS and also what is my VS sopose to be while climbing if any one can help thanx.
Craigy
RE: Climb Problems
Sat Jan 18, 2003 12:22 pm
It all depends on the aircraft, weight, altitude and fuel load.
If you try to climb too rapidly using VS, then the aircraft pitches up too much and speed is lost.
At FL240, the air is thinner and you need to climb more gently. Try +800 or even less.
Craig.
gregjet
RE: Climb Problems
Sat Jan 18, 2003 12:48 pm
thanx but i also wanted to know at what VS am i sopose to climb at thanx again
FltMech9
RE: Climb Problems
Sat Jan 18, 2003 1:30 pm
For the 737 I climb out at 250 kts and about 2,000 fpm until 10,000. Then I increase airspeed to 310 kts and maintain around 1,500 fpm thru FL200. Around FL260 climb at .72 Mach and set vertical speed around 1,000 fpm. I usually finish the last 5,000 feet at around 500 fpm and accelerate to .74 Mach. It works out pretty good, might have to change the numbers for heavier weights and fuel loads.
FltMech9
