dan2002
Flying Past 100,000 Ft On Msfs
Tue Feb 11, 2003 6:24 am
Today i got bored and decided to mess around with msfs. i decided to attempt to go past 100 thousand. I made it past 102k and when i tried to swich views it streaked. if any one has tried it what happned?
Dan2002
A guy asks 'What's Punk?'. I kick over a trash can and its punk. He knocks over a trash can and its trendy.
KCLE
RE: Flying Past 100,000 Ft On Msfs
Tue Feb 11, 2003 10:20 am
FS98 was the only FS in which you can go past 100k. FS02 actually stops you at 100K, and you can't climb anymore, same with 2000. FS98 let you get up to about 110k, but of course everything would be streaky, as you passed the limits of the scenery.
Tue Feb 11, 2003 5:21 pm
What aircraft were you flying?
Airbus Lover
Tue Feb 11, 2003 7:00 pm
I belive flight dymanic will be weird on FS2000 and 2002 after passing aronud 60000 ft? i was flying the blackbird and the fd was going crazy
manzoori
Wed Feb 12, 2003 12:01 am
There's a Space Shuttle available on flightsim.com which will climb straight up to 100k but then it just stops and hangs there.
Like you say the scenery goes all streaky too.
Rez
 Wink/being sarcastic
Flightlineimages DOT Com Photographer & Web Editor. RR Turbines Specialist
dan2002
Wed Feb 12, 2003 6:39 am
i was flying in a space shuttle. its a great craft three moels 1 with xternal tank and srbs 1 wo srbs but with xternal tank and 1 just a shuttle. i got it at <www.surclaro.com>
H. Simpson
Thu Feb 13, 2003 3:28 am
Hopefully FS COF will let you pass to space!
fritzi
Fri Feb 14, 2003 5:06 am
H. Simpson, dont press your luck.
bwc1976
Sat Feb 15, 2003 4:29 am
I remember FS4 let me go up to 300,000 feet or more. It was fun making a jet that weighs 700 lbs and has 20,000 lbs of thrust (not very realistic, I know), blasting off, and then trying to keep the plane under some semblance of control as you came back down. Right around 260,000 things started getting really bumpy, but if you were lucky you could get it back under control and land somewhere on the great expanse of green, even if it wasn't a runway. Anyone who enjoyed FS4 and misses tinkering with it should try X-Plane, it's a lot more fun and easy to mess around designing your own planes than any version of FS later than 4, and the frame rates are smoother like 4 (although the scenery is way better).
BA
Sat Feb 15, 2003 10:21 am
You want to go to space? Get this simply amazing freeware game: http://www.orbitersim.com.
A must for any sim fan.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
