Contrails In FS2002
Thu Mar 13, 2003 4:12 am
Hey!
I've got another question for all the Fligh Simulator freaks:
I've seen lots of screenshots with planes with have huge contrails. I've never seen any contrails in my FS2002!
Any special conditions need for those nice effects???
Thanks so far!
Florian Trojer - Austrian Spotters
dc-10 levo
RE: Contrails In FS2002
Thu Mar 13, 2003 4:18 am
No special conditions needed, just take your jet above 30,000ft and there you have it.
DC-10
manzoori
Thu Mar 13, 2003 5:12 pm
Hi Florian,
DC-10 is right, just take the aircraft above 30kft and the engine contrails will appear.
Some aircraft also have vapour trails built into their code so that in low level flight you get some lovely thin vapour trails off the wingtips. 4 aircraft with this feature spring immediately to mind:
DSB Designs BAe Systems Hawk Mk3
Lago Panavia Tornado
I3D Boeing B1-B
MelJet Boeing 777
I'm sure there are plenty of others but since I'm at work those are the only ones that I can remember.
Hope that helps
Rez
 Wink/being sarcastic
Flightlineimages DOT Com Photographer & Web Editor. RR Turbines Specialist
dragon-wings
Thu Mar 13, 2003 5:35 pm
Project Airbus A320's and POSKY's 747-400 v3's also have the vapor trails Manzoori mentioned.
Don't give up don't ever give up - Jim Valvano
Luxair
Thu Mar 13, 2003 9:55 pm
Hi Spotterboy, just a hind, go to flightsim.com and try to find jettrail.zip and download it.
I did it a few weeks ago and it is an amazing new file who completely changes your jettrails from
the boring standard ones!!! They are much more realistic and stays longer in the sky and when
using real weather (I'm using FS Meteo) than you can even see that they deviate in the wind
direction and deform when turbulences are present!!! You will also see other aircrafts jettrails in the
sky when flying, believe me it is amazing and unbelievable how a little file can change the realism
of flying in FS!!!
Have fun
Ps: if you get a problem finding the file than contact me via mail and I will then send it to you!
jwenting
Thu Mar 13, 2003 9:58 pm
The PSS 747-400 has it too in FS2002, but not in all liveries (or maybe it's dependent on factors I haven't seen with all liveries I have).
I wish I were flying
dragon-wings
Fri Mar 14, 2003 5:12 am
Luxair....Can you post a screenshot or two of the new contrails?
dragon-wings
Fri Mar 14, 2003 5:16 am
Also will the new contrails work on all planes in FS2002? Or just some of them?
Fri Mar 14, 2003 8:02 am
Hello,
Dragon-wings, Contrails will work on all Boeing aircraft above 30,000ft but I'm not sure if it'll work on the Learjet 45 as the model hasn't changed from FS2000. Contrails will not work on all prop aircraft, Hope that helps Smile.
EAC_732
Luxair
Fri Mar 14, 2003 6:15 pm
Hi Dragon-wings, for the screenshots, I have then first to read how to make them and how to post them here
in the forum!!! But I can answer your 2nd question with Yes, it works on all the other aircrafts (jets, for the props I donno) for so far as I could see. It works well even when using 3rd part aircrafts as AI traffic. I'm remember, I flew yesterday from Kandahar to Tehran with my RAF VC10 and I was at around fl 360 and a few minutes before starting my descend I encountered over Iran an Iran air Airbus A310 and one A330 they where also descending for Tehran airport (Meharabat) but where still above fl 300 so I could cleary see the amazing jettrails of the aircrafts and how they stay in the air for a long time ! Very nice to see  Smile/happy/getting dizzy
CPH-R
Fri Mar 14, 2003 11:06 pm
Just to make it clear: The contrails will appear on all aircraft no matter what version of FS it was developed for. Some addon aircrafts also have built-in vortices and the likes.
dc-10 levo
Sat Mar 15, 2003 2:49 am
On some aircraft, if you press the letter 'I' the contrails will appear even if you're below FL300.
DC-10
