AmericanF100
Flight Sim And RAM...
Wed Jul 30, 2003 1:12 pm
Ok, I just got FS2004 today and I am pleased with it... but the smoothness still leaves a little to be desired. My computer has as follows:
Intell Celeron(R)CPU 2.00GHz
1.99GHz
512MB of RAM
(I copied all that right form the comp info as I'm not quite sure if its right, like I don't know why there are 2 GHz, but whatever)
I'm considering buying more RAM... now is RAM the only thing that can help speed up flight sim? Or is there something esle I can do? My disk is pretty free and has 6GB free on the partition where flight sim is installed. If RAM is the only thing that can help, how much should I buy? 128? 256? If there is more I can do, what is it? Any information would be greatly appreciated!
Thanks! Matt~
jwenting
RE: Flight Sim And RAM...
Wed Jul 30, 2003 2:17 pm
You don't state your OS and videocard, so I have to guess.
Given the age and class of 2GHz Celerons your machine likely has a geForce 2MX with 32MB and is running Windows ME or XP Home.
Such a videocard is extremely outdated and FS2004 is no longer optimised for them (rather it is optimised for a card 2-3 generations newer, the geForce 4Ti series).
Windows ME (if that is your OS) is generally (also by Microsoft themselves) considered the worst OS they ever released.
Windows XP Home is a lot better but a memory hog, and 512MB is the bare minimum to run it smoothly. Adding a highpower application like FS2004 (especially when it needs to do a lot that a newer videocard would do in hardware) will slow it to a crawl.
I'm afraid you have few options available:
  • live with it. Try reducing display options until you get a decent result
  • get a new PC. At least a PIV-2.4 (not Celeron) with 1GB RAM and a geForce 4Ti4200 with 128MB RAM
  • get a new videocard (geForce 4Ti4200 with 64MB RAM would do) and another 512MB RAM
First option is the cheapest of course.
Second option is the best.
Third is a compromise. Won't give you the performance of the second but better than the first at a lower price compared to a new PC.
If you want to run the very latest highend games at top performance expect to need the very latest hardware as well (and in case of bleeding tech like what Microsoft uses in the FS line you won't be able to run it at full settings and optimal performance except on hardware that's not yet on the market as the developer wants it to remain appealing for several years, giving people the option to increase their settings as hardware power increases).
I wish I were flying
AmericanF100
Thu Jul 31, 2003 12:26 am
Well my computer is actually new just this year, and the video card I have is an Intel(R)82845G/GL/GE/PE/GV and FS2004 is not running poorly, I'd just like it to run a litte more smoothy. (I copied that video card number right from flight sim) So obviously I'm not going to be buying a new computer. Thanks for the info though.
Matt~
portcolumbus
Thu Jul 31, 2003 1:19 am
Intel graphics? Sounds like shared video RAM to me. That makes it even worse.
jwenting
Thu Jul 31, 2003 2:20 am
It is. Most if not all onboard videocards use shared RAM.
Given you are a bit low already it definitely makes things worse (not even taking into account that main RAM is slower than dedicated videoRAM by an order of magnitude).
767ALLTHEWAY
Thu Jul 31, 2003 4:52 am
I dont know what ive got, its an nVIDIA Card (FX5200) but I have 1.50 GB of RAM, and from what ive heard that Direct 3D runs most of its graphics of a computers proccesor?
"Courage is not the absence of fear, but rather the judgement that something else is more important than fear"
jwenting
Thu Jul 31, 2003 5:00 am
You heard wrong  Smile
Direct3D (part of DirectX) will use whatever hardware accelleration functions are available on the videocard.
When a function is not available only then is it executed by the CPU.
GF FX should be able to do most things in hardware, seeing it's a fully DirectX9 compliant card (but things might depend on the drivers and who knows how true such statements are).
A GF MX card on the other hand lacks the advanced 3D support and will indeed relegate most tasks to the main CPU which causes a slowdown in your game.
767ALLTHEWAY
Thu Jul 31, 2003 12:20 pm
Jwenting, well thank you for cleaing that up for me, im not much of a computer technical wizard guru. But i am optimistic that when i get my copy (should arrive soon) that 04 will run well. Best Regards to everyone.
