fspilot747
FlightSim 2002 Issue..any Insight?
Mon Aug 11, 2003 12:04 pm
Recently, I've been having this framerate problem on the ground.
When I'm taxiing or rolling, the framerates are sickening, and even ATC stutters. However, once my wheels are off the ground it's silky smooth. I only have this problem when I'm on the ground. The frames seem to stutter and go back and fourth. But again, everything is fine in the air. I updated my drivers, and even re-installed the program. Same thing. Any advice?
FSP
cancidas
RE: FlightSim 2002 Issue..any Insight?
Mon Aug 11, 2003 12:18 pm
turn down the density of scenery. that should do it. if it still doesn't work, then you may have to update your graphics card.
"...cannot the kingdom of salvation take me home."
portcolumbus
Mon Aug 11, 2003 12:20 pm
Aircraft shadows make a dent in the FPS, but that probably isn't it.
fspilot747
Mon Aug 11, 2003 12:41 pm
everything is default. I never had this problem before. It used to run fine on dense scenery.
still dont have a clue though..
cancidas
Mon Aug 11, 2003 1:48 pm
the plane you were trying to fly, was it installed as part of FS or did you download it from some other site? if you downloaded it, that might be it.
fspilot747
Mon Aug 11, 2003 2:25 pm
Any plane...and its only when im on the ground too. its bizarre.
FSP
