PizzaPolli
Project Open Sky Problem--help!
Tue Sep 23, 2003 7:04 am
So when try to download more than one of the same type of aircraft onto fs2002 like two 744 one AF one BA I only get the first one I downloaded to show up in my game. Whats going on here? Thank you.
HA_DC9
RE: Project Open Sky Problem--help!
Tue Sep 23, 2003 2:24 pm
Did you click on the drop down box called "airline" of the aircraft you want to fly on the select aircraft screen? If you have multiple airline liveries of the same aircraft, you need to select the airline from the "airline" drop down box.
Sinlock
Tue Sep 23, 2003 11:54 pm
Try looking in the Boeing folder, Sometimes the aircraft will show up in there and not the Project Open Sky folder. This is common with POsky repaints because people change the target folder.
PizzaPolli
Wed Sep 24, 2003 5:19 am
I tried both of your suggestions which embarrasingly enough I had not done before but they still weren't there. I must be just doing something wrong in the dowload process I guess. As long as this is not a problem that others usually have I guess I will just have to keep playing with it until I get it right. Thanks for your help.
wilax
Fri Sep 26, 2003 1:50 pm
What I have done is: when you download a plane, b4 you put it in fs2k4, go into aircraft.cfg file in the main folder of the plane, under flightsim.# (0,1,2,3), go down to the line "ui manufacturer=Boeing" and change Boeing to the airline of your choice and the airline will show up as a manufacturer in the select aircraft menu. Also change the "title=boeing 737" to something different for each version that you have.
Here is an example:
[fltsim.0]
title=738aa
sim=Boeing737-400
model=
panel=
sound=
texture=aa
visual_damage=1
kb_checklists=Boeing737-400_check
kb_reference=Boeing737-400_ref
atc_id=
atc_airline=AMERICAN
atc_flight_number=43243
ui_manufacturer=american
ui_type=737-800
ui_variation=American Airlines
description=One should hardly be surprised that the world's most
hope this helps...
