ngr
FS2004 Texture Problems
Mon Nov 03, 2003 7:14 am
I am having problems with the aircraft textures in FS 2004. Every aircraft appears extremely blurry. Most of the buildings appear fine, and I have experimented with changing around the settings under display...what am I doing wrong, and how do I fix this?
Thanks.
markyboy
RE: FS2004 Texture Problems
Mon Nov 03, 2003 9:05 am
I never had this problem myself however I reckon others do or did as I saw a set of replacement textures for all of the default aircraft a while back on both avsim and flightsim.com If I remember correctly it stated that they were to replace the blurred originals. As I say I don't have this problem so I never tried them but you may want to give them a shot.
Hope it helps,
markyboy.
Mon Nov 03, 2003 12:18 pm
I had the same problem. I used the replacement textures, and they work pretty well.
-Normal
