flymia
Looking For 2004 Planes?
Mon Nov 03, 2003 10:58 am
I need help i am going to download the Dash-8 Panel and Fokker 50 panel for 2004 so i am looking for those aircraft. Also any 737 NG. Because i am getting that panel as well. I cant find any of the planes. I look under GMAX 2002 and 2004. on AVSIM. If anyone has one of those aircrafts or an ATR that works or is for 2004 please tell me. Thank You.
RE: Looking For 2004 Planes?
Mon Nov 03, 2003 12:30 pm
I've noticed that simviation.com has a lot more FS2004 stuff than AVSIM does. In fact, I'm downloading some good 2004 stuff as I type this...
-Normal
Wed Nov 05, 2003 2:39 am
Picked up some really sweet stuff on AVSIM. Do a search of the entire "FS 2004 Original Aircraft." I stayed up way too late downloading great airplanes, namely a BEAUTIFUL Bellanca Decathalon. This is perhaps one of the best aircraft that I have ever downloaded. And there are a lot of other great airplanes specifically for FS 2004.
-Normal
Aaron747
Wed Nov 05, 2003 3:36 am
Try the FFX 737-800. There's some great liveries available for it. As for the previous series of 737NG mastery, FFG unfortunately designed all of theirs in FSDS and are doing a ground-up rebuild in GMAX, so I've heard.
subzero
Fri Nov 07, 2003 2:48 am
I've actaully had some luck at Flightsim.com, You might want to check them out too...
Richard
