sushka
Strange Problem With FS2004
Fri Dec 26, 2003 7:46 am
I just got FS2004 and already have a problem.
Everytime I transmit on ATC the entire screen goes black for a second. It is almost as if it is blinking. Has anyone else had this problem? What should I do?
Pershoyu Spravoyu Litaki!
apuneger
RE: Strange Problem With FS2004
Fri Dec 26, 2003 8:34 am
Well, usually when there's a problem with the way FS 2004 is displayed, we (= Airliners.net community) recommend users to check if their video card drivers are up to date.
Chances are it's a driver-related problem. Updating, or re-installing drivers might fix the problem...
Ivan
Ivan Coninx - Brussels Aviation Photography
markyboy
Fri Dec 26, 2003 11:32 am
Agreed, more than likely a video card issue. If you are using an NVIDIA card and have Anti Aliasing selected, try switching it off. If this doesn't cure it or you are using another type of card I would look at another set of drivers.
Best of Luck,
markyboy.
