StarAC17
FS2004 Help
Tue Jan 06, 2004 5:33 am
Can someone please explain to me why when I fly either POSKY or Meljet planes in Fs2004 why the Yaw Damper switch will not work at all they worked fine in FS2002 but not they don't work at all and landing is quite difficult. The problem has occurred with the POSKY 744,762,763 and the Meljet 744 and 777.
Is there a way to fix this?
Engineers Rule The World!!!!!
Shawn Patrick
RE: FS2004 Help
Tue Jan 06, 2004 6:06 am
I know why - they're FS2002 aircraft, and not everything is upward-comptable.
StarAC17
RE: FS2004 Help
Tue Jan 06, 2004 10:53 am
I know, but is there any way to fix it?
Continental
RE: FS2004 Help
Tue Jan 06, 2004 11:06 am
Perhaps you missed a file while copying them into FS2004? I have the Meljet 747, I flew a flight last night EWR-LHR, and everything worked out fine.
co
radarbeam
RE: FS2004 Help
Tue Jan 06, 2004 12:35 pm
I heard somewhere that Yaw Damper isn't modeled in FS2004, that would explain why it doesn't work.
Radarbeam
StarAC17
RE: FS2004 Help
Tue Jan 06, 2004 4:09 pm
It seems to work with the default 747-400 and the 777-300 jets that come with the game. I assume that FS2004 doesn't understand the FS2002 models exactly like FS2002
RE: FS2004 Help
Tue Jan 06, 2004 6:20 pm
I also know that the Yaw Damper worked fine in FS2002... I've not seen any model where it worked in FS2004...
Maybe the new POSKY A343 will have a working one...  Insane
United_fan
RE: FS2004 Help
Tue Jan 06, 2004 10:28 pm
Okay,here we go! You can add it by right clicking START,program files , FS9 , Aircraft , then click on the aircraft you want to add yaw damper to. Then click on the white & blue 'aircraft' folder , locate under [autopilot] the line that says 'yaw_damper_gain=0.000000 ' ,change it to 1.000000, then save . This will now allow the switch to work. Some panels/planes do not have a 'yaw_damper_gain' line in the config,but you can add it under the [autopliot] line .
The above file can also be used to change the 'manufacturer' of the plane from 'PROJECT OPENSKY' to 'Boeing' , so all your Boeings line up.
Hope this helps!
Champagne For My Real Friends,and Real Pain For My Sham Friends
StarAC17
RE: FS2004 Help
Wed Jan 07, 2004 12:49 am
I'll be sure to try this United_Fan thanks  Big thumbs up
Users browsing this forum: Google [Bot] and 1 guest
