chicago757
ATC For Flight Simulator
Sun Feb 29, 2004 4:11 pm
Is there a way you can get the FS ATC to tell you something like United 101 turn left heading 290 descend and maintain ten thousand cleared to the ILS runway 29L ? << just an example....or is there an upgrade for this?
Go White Sox!!!!
Craigy
RE: ATC For Flight Simulator
Sun Feb 29, 2004 5:55 pm
It should do something like that if you are in an IFR flight. You select IFR on the flight planner page.
regards,
Craig.
InnocuousFox
Mon Mar 01, 2004 12:56 am
If you are on FS2002 or later, it should tell you all sorts of neat things.
Dave Mark - Intrinsic Algorithm - Reducing the world to mathematical equations!
Craigy
Mon Mar 01, 2004 1:21 am
Here is the transcript of my arrival into Nalples.
SPEED BIRD 131, Turn left heading 330
SPEED BIRD 131, Descend and maintain 5,300
SPEED BIRD 131, you are 27 miles east. Turn left heading 270, Descend and maintain 3,900 Cleared ILS runway 24 approach. Maintain 3,900 until established on the localizer. Contact Naples Tower on 118.5.
SPEED BIRD 131, Naples Tower. Make straight in, runway 24. Altimeter 2992.
If you are using FS2004. ATC will give you a step climb to your cruising altitude too.
Craig.
InnocuousFox
Mon Mar 01, 2004 2:26 am
"If you are using FS2004. ATC will give you a step climb to your cruising altitude too."
That was annoying in 2002. Ok... I go from wheels up over to departure and straight to 37,000. *sigh*
