planemad
FS 2004 Callsign
Wed Mar 10, 2004 6:44 am
Is there a way to get new airline callsigns other than the ones already there or that come with other aircraft?
KLM777
RE: FS 2004 Callsign
Wed Mar 10, 2004 7:22 am
Yes there is: at http://www.avsim.com you can download "EditVoicepack 3.0", which has quite a number of callsigns, otherwise you can add others to the program. You need to install the Microsoft .Net Framework 1.1 in order to get it to work (see the manual).
Jeroen
Every landing is a controlled crash
kalakaua
Wed Mar 10, 2004 11:45 am
Does anyone know the reason why they left out Southwest?!
Gravity explains the motions of the planets, but it cannot explain who set the planets in motion.
LHcapt2007
Wed Mar 10, 2004 5:17 pm
YEA NO KIDDIN i dream of hearing southwest in ATC, very sad...
Check this website if you want all the atc codes for airline callsigns...
http://www.homepages.mcb.net/bones/04FS/data/fsdata.htm
Next, just go to the aircraft folder of the plane you want to change, (FS9/aircraft/b737_400/aircraft.cfg) and go to the aircraft.cfg document; open it with WORDPAD(right click,open with-> wordpad)!! Once you're there you will see where it says "atc_airline= " under the [flightsim.0] menu;now this is where you type in the airline callsign from the above website. Notice if you scroll down there are many other "atc_airlines= ",so you can change more names!!
i.e. type in "atc_airline=frontier flight" and atc will say"frontier flight 1123, cleared for takeoff". its gets ever more advanced and technical from here!!
ENJOY!
LHcapt2007
TNCM
LHcapt2007
Wed Mar 10, 2004 5:23 pm
The best I can get is Skywest (sounding like Southwest). Someone out there has to know how to add a callsign in the atc program (even if its your own recorded voice). Any takers to THIS challenge or just wait til FS2006?
LHCapt2007
long live the 732!!
Photo © Frank C. Duarte Jr.
TNCM
clrd2go
Thu Mar 11, 2004 1:28 am
If you follow KLM777's suggestion, you can get Southwest and just about
every known airline. And using Editvoicepack is a breeze (once you
have the .net framework.
Jim
What a long strange trip it's been
LHcapt2007
Thu Mar 11, 2004 3:52 am
o yes i see, the topic needs to be more specific: how can you get NEW atc (new voices) callsigns in addition to all of the ones already offered in FS9? sounds like he's asking how to hear other than standard callsigns, which you can use as long as they're already recorded; i thought that was too easy! well if it was meant either way we are all happy now!  Smile
Thanks for the kind suggestion!
LHcapt2007
TNCM
wilax
Fri Mar 12, 2004 1:33 pm
Hold UP!!!
I have had "Southwest" from the beginning, even before I got the Editvoicepak.
I just opened up the airlines.cfg file and added southwest, simple.
kalakaua
Fri Mar 12, 2004 1:47 pm
Wilax, I did that, and kept on trying. But somehow, it still didn't work until I got Editvoicepak!
