Pe@rson
'W' Won't Work On FS2002
Sun Apr 04, 2004 3:01 am
Hi folks,
I can usually press 'W' and get the cockpit changed so that I can see better. However, this feature hasn't been working for the past three hours. I don't know what it could be. An yideas?
Pe@rson
RE: 'W' Won't Work On FS2002
Sun Apr 04, 2004 3:17 am
Grrr! Now I can't pushback! I don't know what's happening, but whatever it is, it is VERY frustrating and annoying. It has never happened before. I don't have num lock or anything on. Any ideas? Hopefully someone will know what the problem is and how best to remedy it.
A3204eva
Mon Apr 05, 2004 11:15 pm
Don't worry - This happened to me.
All you need to do is put the 'Control Assignments' back to the default setting by pressing the default button.
Hope this helps
A3204eva Smile
"They have lady pilots......... they're not that good, but they have 'em"
Pe@rson
Tue Apr 06, 2004 6:14 am
Thanks for your reply.
Any idea when I find the 'Control Assignments'? I looked on settings and 'assignments' but couldn't find it. Any directions would be appreciated.
Cheers.  Smile
A3204eva
Tue Apr 06, 2004 6:54 am
It should be: Settings, then in the controls box select assignments and then there are 4 buttons at the bottom - it says 'Reset Defaults'
Try that. Let me know if it works or if you need more help.
A3204eva Smile
Pe@rson
Tue Apr 06, 2004 7:01 am
Yep it worked! Thanks a lot. I tried that earlier, but it didn't work then. Odd. Thanks again.
Btw, are you coming to our Mega MAN Meet on the 10th and 11th July? It's not far from Preston! Hope you come. Check the non-av forum for full details.
A3204eva
Tue Apr 06, 2004 7:13 pm
I'll gonna try to go. Can't promise anything yet.
A3204eva Smile/happy/getting dizzy
Users browsing this forum: Yahoo [Bot] and 1 guest
