chicago757
FS2002/2004 Sounds.....
Wed Apr 07, 2004 4:13 pm
How do you install downloaded sounds into the FS2002/2004 aircraft, and replace the old default boring one?
Kevin
Go White Sox!!!!
CO737
RE: FS2002/2004 Sounds.....
Thu Apr 08, 2004 4:03 am
Hi Kevin,
All that you have to do is move all of the sound files (.wav) into the FS2002/2004 SOUND folder, and then move the sound.cfg file into the sound file of whatever aircraft you want to put the sounds in. That should work.
Happy Flying,
CO737
SA006
Thu Apr 08, 2004 6:07 am
Or....take the downloaded file. take the folder that contains the sounds and cut and paste onto your desktop. The go to the folder of the aircraft you want to put the sounds in. Then delete the folder "sound" in the aircraft's folder. Then go to your downloaded folder and rename it simply "sound". Then just simply put it in the desired aircraft folder and there you are!  Smile/happy/getting dizzy I know it sounds long and hard but it's easy (at least for me) and safe
Regards Big grin
SA006
Proudly South African
