gkirk
Ifdg 757 Problem
Wed Jun 16, 2004 11:01 pm
Hi all,
I just downloaded a US Airways 757 from Avsim, and when trying it out for the first time, came over this problem(may have been my fault instead of the model). When pushing back from Manchester, stopping the pushback, the a/c flipped onto its back and ended up as a crash.
Now, I think it may have been my fault, as I think I left the brakes on during pushback, but this doesnt happen with other a/c that I have so, anyone any ideas?
A3204eva
RE: Ifdg 757 Problem
Thu Jun 17, 2004 12:07 am
This happened to me once, but with a Cessna (don't ask why a Cessna was being pushed back), and it fell onto it's tail. I think this was because it was a light aircraft.
Maybe the plane you downloaded, in the .cfg file, they might of got the weight wrong.
Just an idea
Join my VA
A320
"They have lady pilots......... they're not that good, but they have 'em"
Aaron747
Thu Jun 17, 2004 10:20 am
Easy solution for ya:
POSKY 757
wilax
Wed Jun 23, 2004 10:07 am
Compared to POSKY, the IFDG 757 is kinda crappy. Dump all your IFDG 757's now and upgrade to POSKY. The only thing is that the POSKY's do not have wing flex, but everything else is better including descent airspeed control. You will no longer have to descend with full speed brakes...
clrd2go
Wed Jun 23, 2004 11:40 am
I thought I was the only one having a problem with airspeed control on the
IFDG 757!
Jim
What a long strange trip it's been
LHcapt2007
Wed Jun 23, 2004 2:51 pm
Don't set the parking brake, take it off b4 you push back.
Don't touch the brakes when you hit "shift-p" the second time to stop the aircraft, it'll stop on it's own.
When in spot-plane view mode (more so than cockpit view), you can run across the invisible bumps(gliches) which cause enough stress to the aircraft to make it crash, especially in heavies.
I have the same aircraft model and airline; no problems ever.
LHcapt2007
TNCM
wilax
Fri Jun 25, 2004 1:06 pm
POSKY, POSKY, POSKY,
Dump the IFDG
kalakaua
Fri Jun 25, 2004 7:09 pm
Are the iFDG A320's okay?
Gravity explains the motions of the planets, but it cannot explain who set the planets in motion.
N139J
Fri Jun 25, 2004 11:57 pm
It was the pbrake. Release it before pushback, set it after pushback.
POSKY is the best 57 out there.
KLM-MD11
Sat Jun 26, 2004 2:04 am
I don't like the A320 from IFDG... no realistic flight model at all!
GELUK IS GELUL MET EEN K
A340600
Sat Jun 26, 2004 7:05 pm
The IFDG A321's are amazing!!! BUT I don't like the way there's no touchdown smoke
Sam
wilax
Sun Jun 27, 2004 3:36 pm
I love the IFDG a320, a321, md11, I get smoke on touchdown with all of them. You must put the smoke.fx in the effects folder to make it work.
apollo13
Sun Jun 27, 2004 4:11 pm
Yeah I remember thant before the POSKY 757's came out for FS2004, i would use the IFDG 757 and when on takeoff, the plane would climb very steep. The POSKY 757 is great and so is the IFDG MD-11 and the 767!!!!
wilax
Sun Jun 27, 2004 4:24 pm
Now the IFDG 767,,, Its a good plane but the visual model is not accurate. The engines are too small and the curveture at the forward base of the tail fin is less like a 767 and more like a NG737, and that stupid flag that shoots out of the roof... Oh yeah, the ailerons are reversed in operation on the -200, -400 still after they made a fix for the -300. It does have wingviews which is lacking on the POSKY's so being the slave to wingviews that I am, I use IFDG's...
FlyingColours
Sun Jun 27, 2004 6:47 pm
I used to leave the parking brake on during Pushback and when I'd stop the nose would lift up then slam down again but it never crashed or was significant enough to crash. I turn the brakes off before I P/B and turn them on afterwards.
O/T - When do you guys start your engines?
I use the POSKY 757s but thats because I was brought up with the FFG models which are no longer avaliable (A shame because they had a Flying Colours which would look good on an updated model). I didn't like the IFDG 767s, but I love their Airbus aircraft very much.
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
qr332
Mon Jun 28, 2004 10:36 pm
iFDG have amazing aircraft, and I love them with the expetions of the 757 & 767, where POSKY definatley kicks iFDG's ass. the A3xx series so far are really good and the MD-11 was also really good, I cant wait till they realease the new one.
"The greatest threat to knowledge is not ignorance, it is the illusion of knowledge."
LHcapt2007
Wed Jun 30, 2004 2:21 pm
Opensky doesn't even have wing textures in it's 767 models, IFDG wins but i have to admit the textures are nice.
LHcapt2007
TNCM
