planemad
FS 2K4 Panel Problem
Sat Jun 26, 2004 7:34 am
As you can see the panel repeats itself and flickers but when I move it back to normal it is fine. How can i fix this problem?
eclipseflight7
RE: FS 2K4 Panel Problem
Sat Jun 26, 2004 8:24 am
Go to your FS9/aircraft/panel folder and open up the panel CFG file. Paste this:
[fltsim]
alias=b777_300panel
Save it and then it should work.
Holy sh*ts and burritos.
planemad
Sat Jun 26, 2004 8:28 am
I pasted it at the top of the panel.cfg.
I will check if it works now
planemad
Sat Jun 26, 2004 8:49 am
Oh dear.
It has become a Cessna panel now.
I will delete that.
eclipseflight7
Sat Jun 26, 2004 9:11 am
Okay, lets see if this works. Paste this into the panel.cfg:
// Panel Configuration File
// Boeing 777-300
// Copyright (c) 1999-2003 Microsoft Corporation. All rights reserved.
[Window Titles]
Window00=Main Panel
window01=Radio Stack
Window02=GPS
window03=Throttle Quadrant
window04=Compass
Window05=Mini Panel
[Window00]
size_mm=640
position=7
visible=1
ident=MAIN_PANEL
gauge00=Boeing777-300!Anti_Ice_Switch,406,15
gauge01=Boeing777-300!Ignition_Left,459,15
gauge02=Boeing777-300!Ignition_Right,537,15
gauge03=Boeing777-300!Fuel_Selector,588,15
gauge04=Boeing777-300!Autobrake,554,404
gauge05=Boeing777-300!Gear_Lever,602,380
gauge06=Boeing777-300!Pitch_Trim_Ind,554,248
gauge07=Boeing777-300!Pitch_Trim_Knob,558,345
gauge08=Boeing777-300!Rudder_Trim_Ind,584,308
gauge09=Boeing777-300!Rudder_Trim_Knob,597,339
gauge10=Boeing777-300!Aileron_Trim_Ind,583,247
gauge11=Boeing777-300!Aileron_Trim_Switch,595,276
gauge13=Boeing777-300!Beacon_Nav_Light_Switch,9,380
gauge14=Boeing777-300!Nose_Light_Switch,1,431
gauge15=Boeing777-300!Strobe_Light_Switch,29,431
gauge16=Boeing777-300!Taxi_Light_Switch,49,431
gauge17=Boeing777-300!Clock,0,282
gauge18=Boeing777-300!Autopilot,255,182
gauge19=Boeing777-300!Backup_Attitude,476,246
gauge20=Boeing777-300!Backup_Altimeter,476,323
gauge21=Boeing777-300!Backup_Airspeed,476,400
gauge22=Boeing777-300!PFD,75,255
gauge23=Boeing777-300!MFD,274,255
gauge24=Boeing777-300!Avionics_Switch,21,244
gauge25=Boeing777-300!Master_Caution,225,186
gauge26=Boeing777-300!Autostart,500,17
gauge31=SimIcons!Kneeboard Icon, 156, 457
gauge32=SimIcons!ATC Icon, 169, 457
gauge33=SimIcons!Map Icon, 182, 457
gauge34=SimIcons!Avionics Icon, 195, 457
gauge35=SimIcons!GPS Icon, 208, 457
gauge36=SimIcons!ECU Icon, 221, 457
gauge37=SimIcons!Compass Icon, 234, 457
[Window01]
size_mm=127,347
position=8
visible=0
BACKGROUND_COLOR=2,2,2
ident=RADIO_STACK_PANEL
gauge00=Boeing777-300!Comm 1, 0, 0
gauge01=Boeing777-300!Comm 2, 0, 54
gauge02=Boeing777-300!Nav 1, 0, 108
gauge03=Boeing777-300!Nav 2, 0, 162
gauge04=Boeing777-300!Transponder, 0, 216
gauge05=Boeing777-300!ADF, 0, 265
gauge06=Boeing777-300!Audio, 0, 319
[Window02]
size_mm=456,378
window_size=0.5
position=8
BACKGROUND_COLOR=0,0,0
VISIBLE=0
ident=GPS_PANEL
gauge00=fs9gps!gps_500, 0,0
[Window03]
size_mm=201
position=0
BACKGROUND_COLOR=16,16,16
visible=0
ident=THROTTLE_PANEL
gauge00=Boeing777-300!Throttle Quadrant, 0, 0
[Window04]
background_color=138,118,106
size_mm=70
position=2
visible=0
ident=COMPASS_PANEL
gauge00=Magnetic_Compass!Magnetic-Compass,0,0
[Window05]
position=7
size_mm=398,224
child_3d=1
background_color=0,0,0
ident=MINIPANEL
gauge00=Boeing777-300!PFD,0,0
gauge01=Boeing777-300!MFD,201,1
[VCockpit01]
size_mm=512,512
pixel_size=512,512
texture=$777_1
gauge00=Boeing777-300!PFD, 0, 222, 255, 288
gauge01=Boeing777-300!MFD, 256, 222, 255, 288
gauge02=Boeing777-300!Autopilot, 0, 0, 512, 58
gauge03=Boeing777-300!Clock, 1, 96, 122, 125
gauge04=Boeing777-300!Backup_Attitude, 256, 94, 125, 125
gauge05=Boeing777-300!Backup_Airspeed, 128, 94, 125, 125
gauge06=Boeing777-300!Backup_Altimeter, 384, 94, 125, 125
gauge07=Boeing777-300!Aileron_Trim_Ind, 0, 59, 81, 34
gauge08=Boeing777-300!Rudder_Trim_Ind, 83, 59, 81, 34
gauge09=Boeing777-300!Autostart, 166, 59, 30, 34
[VCockpit02]
size_mm=256,256
pixel_size=256,256
texture=$777_2
gauge00=Boeing777-300!Comm 1, 0, 0, 127, 54
gauge01=Boeing777-300!Comm 2, 0, 54, 127, 54
gauge02=Boeing777-300!Nav 1, 0, 108, 127, 54
gauge03=Boeing777-300!Nav 2, 0, 162, 127, 54
gauge04=Boeing777-300!Transponder, 129, 0, 127, 49
gauge05=Boeing777-300!ADF, 129, 49, 127, 54
gauge06=Boeing777-300!Audio, 0, 216, 125, 26
gauge07=Magnetic_Compass!Magnetic-Compass, 172, 103, 84, 82
gauge08=Boeing777-300!Pitch_Trim_Ind, 128, 103, 44, 152
gauge09=Boeing777-300!Beacon_Nav_Light_Switch, 173, 187, 83, 50
[Default View]
X=0
Y=0
SIZE_X=8192
SIZE_Y=3100
[Color]
Day=255,255,255
Night=159,92,124
Luminous=181,64,64
planemad
Sat Jun 26, 2004 9:25 am
That doesnt work and all my a/c have a problem. I will re-install.
