MaverickM11
FS2004: I Can't Control All Engines
Sat Jun 26, 2004 10:37 am
Lately FS2004 has not allowed me to control 2 or more engines occasionally; no matter what I do I can only control the #1 engine from the keyboard. If I open up the throttle panel I can use the mouse to advance all engines but that's annoying. Anybody else have this problem? Any solutions?
E pur si muove -Galileo
dinker225
RE: FS2004: I Can't Control All Engines
Sat Jun 26, 2004 11:00 am
Try pressing E then 1,2,3,4. E is the engine select and 1,2,3,4 is the engine number you are selecting. If you hit E then 1,2,3,4 all at once it should reselect all the enges. Only needs to be done 1 and 2 if there are only 2 engines on the plane. Hope that makes sense.
Dinker
Two rules in aviation, don't hit anything and don't run out of gas, cause if you run out of gas yer gonna hit something.
MaverickM11
Sat Jun 26, 2004 11:29 am
I've tried that and it results in the same thing; only engine #1 is controllable.
NWADC9
Sat Jun 26, 2004 12:12 pm
You have to do it quickly. When I start my engines on a 2+ engine airplane, I can only control #1. But when I press "E, 1+2..." I can control all engines.
I convert Jet A and 100LL into noise.
planemad
Sat Jun 26, 2004 6:22 pm
I use E 1+2 etc but sometimes it doesn't work and only 1 engine can be controlled so I just go to select aircraft and press enter to you go into the same aircraft that you left but controlling both engines.
A3204eva
Sat Jun 26, 2004 7:01 pm
That happens to me on FS2002, I have to change to a different aircraft and then straight back to my original Smile
That always works for me.
A320
"They have lady pilots......... they're not that good, but they have 'em"
eclipseflight7
Sun Jun 27, 2004 12:30 am
It's because of autostart. When you press ctrl-e then it only selects the first engine. What might fix it is going into the assignments screen and changing the select engine to a key that won't get in the way.
Holy sh*ts and burritos.
LHcapt2007
Wed Jun 30, 2004 2:15 pm
My key sequence is: (4 engines) E+1+2, then within 1 sec, E+3+4 and it works everytime. Make sure that E,1,2 are held down together, then, release the 1+2 buttons while holding the E button, then hit 3 & 4 at the same time. Remember, hold E the whole time.
Quick way to start 747 if all are off, click all 4 starter buttons on the upper panel then manually open the fuel valves(below the throttles) when they hit their proper Nspeed. CTRL+E takes way too long sometimes and manual control feels more real.
LHcapt2007
TNCM
NWADC9
Thu Jul 01, 2004 12:58 pm
I just press ctrl+e, repeatedly pressing it untill I hear all engines going. Works every time Big thumbs up
