boeing 747-311
Opening Doors In Flight Sim
Sun Aug 22, 2004 11:01 am
How do you open all the different doors in flight sim 2004? any info would be great!
Come fly with US
United4everDEN
RE: Opening Doors In Flight Sim
Sun Aug 22, 2004 2:40 pm
Eh? What are you talking about?
CanadianNorth
Sun Aug 22, 2004 4:18 pm
If yer talking about doors on the aircrafts I know the main door can be opened via pressing Shift+E, but I heard that on some aircrafts you can open several doors, something that I have yet to figure out.
CanadianNorth
Way to go, nice and slow, never late, 748!
boeing 747-311
Sun Aug 22, 2004 4:53 pm
I know about the main exit, but some of the pictures u can see with cargo doors, emergency doorsopen all the exits and doors.
Come fly with US
Craigy
Sun Aug 22, 2004 5:43 pm
It is usually SHIFT-E+1, SHIFT-E+2 etc.
Craig.
ZKSUJ
Sun Aug 22, 2004 5:54 pm
Thanks, I thought is was ctrl E and that kind of started up the engines after shut down.
LHR27C
Mon Aug 23, 2004 3:05 am
You can also try Shift+F and Shift+T for, strictly speaking, tailhook and wingfold although they are sometimes assigned to doors. It should say in the aircraft's readme what shortcuts are available and what they do.
Once you have tasted flight, you will walk the earth with your eyes turned forever skyward
Santhosh
Mon Aug 23, 2004 6:02 am
The most generally used keys by designers are already mensioned above.Recently I downloaded an Sabena A319 aircraft from avsim it uses keys as follows
1) Shift E+1- To open the main exit
2) Shift E+2- To open all other 3 doors in the aircraft
3) Shift T - To open both the cargo doors
4) Shift W - To open the aircondetioning vents
4) Shift F - To drop the controls surfaces when aircraft is parked.
Sometimes different designers assign different keys for different features but this is for your general information.Hope it helps
Santhosh
Happy Landings :)
boeing 747-311
Mon Aug 23, 2004 6:22 am
Santhosh-
I tried all those in my game and none of them worked for the main exit could there be some option not on or what do u think?
Come fly with US
Santhosh
Mon Aug 23, 2004 6:37 am
B-747-311
Sir I was trying to figure out the problem.Well are you sure that the aircraft the you use has opening doors?If yes then may be the designer might have used some other combination of keys.They reading the readme files if at all the aircraft has any.
Or sometimes it happens with me,when I try to open the other doors than the main exit,it sometimes doesn't happen at all. In that case I just reset the aircraft and then everything functions normally.Hope this helps you
Santhosh
Happy Landings :)
boeing 747-311
Mon Aug 23, 2004 6:50 am
Yes i am sure they have opeing doors because i looked in the readme and i pressed what the button said and it just didnt work, so i am unsure what is going on.
Come fly with US
FlyingColours
Mon Aug 23, 2004 7:07 am
I have found that with some aircraft once I have completed a flight I am unable to open all the other passenger doors barring the passenger boarding door. I can open the cargo bay doors no problem-o.
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
boeing 747-311
Mon Aug 23, 2004 12:27 pm
phil i amable to open th emain exit but not the cargo doors.
Come fly with US
