N754AN
FS2004: Take Offs With A Mind Of Their Own!
Tue Aug 24, 2004 12:48 am
Hi all,
I have just downloaded an A330-200 in MEA (Middle East Airlines) colours, I was doing a mini test flight around Seattle.. as I was on my take-off roll the plane lifted itself off the runway and climbed!
I didnt have the Auto-Throttle nor the Auto Pilot activated!
Why did this happen?
N754AN
Fankoooooooo
SA006
RE: FS2004: Take Offs With A Mind Of Their Own!
Tue Aug 24, 2004 1:00 am
Well...it happens for me when on low fuel and lots of flap...especially my AirbusNG planes.
SA006
Proudly South African
N754AN
Tue Aug 24, 2004 1:06 am
Thanks for your reply...
At the moment (as I am fairly new to FS) I fly with unlimited fuel, and my flaps were down at 5, which is normal for a take off roll.
And the same thing has just happened on a Britannia 757-200!!
There must be something within the files of certain downloaded aircraft that make them do this... I'd much rather do the lifting off the runway myself, as it takes some of the fun out of proceedings if its done for you!
Geez
Fankoooooooo
FlyingColours
Tue Aug 24, 2004 2:16 am
It's normal with flight sim, the wings generate lift and as you thunder down the runway the lift is getting greater, all that's happening is that you are thundering down past T/O speed and the aircraft will pitch itself up, on the POSKY A332 (Full with Flaps 10) VR should be 155/165 knots KIAS, go too far past that and it will climb itself.
Same thing happens with the default cessnas too.
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
clrd2go
Tue Aug 24, 2004 2:45 am
Check your trim.
Jim
What a long strange trip it's been
flymia
Tue Aug 24, 2004 3:45 am
Even in real life a Cessna will pull up its self. With Flaps and it matters how much trim.
Continental
Tue Aug 24, 2004 7:03 am
Yep, Jim is most likely right. Check the trim. Make sure the elevators are level and not up, because if your trim is set incorrectly with the elevators up, it will lift off as soon as it's possible on it's own.
N754AN
Tue Aug 24, 2004 8:22 am
Thanks for you help guys,
I shall check that stuff out on my next flight which is in just over an hour...
MIA-GRU-GIG
Varig MD11.. Flight 8819
 Smile/happy/getting dizzy
Fankoooooooo
CanadianNorth
Tue Aug 24, 2004 12:59 pm
Last night I took my Canadian North 732 for a spin around YXY for something to do, and apparently my alerons were stuck in a position that to hold the wings level meant having the stick about 3/4 of the way to the far left (in other words all the way left to make a small left turn or about centre to make a small right turn). I didn't notice it till liftoff when the bugger just about put a wing into the ground, but I did manage to (with some difficulty) slowly and carefully turn it around fly out a little bit turn around again and somehow lined it up with the runway (atleast to the point where I could slam it down and use the nosewheel a little to put it on the centerline). I did do a replay and discovered they were in that position during taxi n all aswel..... Anyone ever had that?
CanadianNorth
[Edited 2004-08-24 06:00:34]
HS-748, just like a 747 but better!
tbanger
Tue Aug 24, 2004 6:13 pm
CanadianNorth Yes. It happens when you have stacks of fuel in your right tank and none in your left.
ZKSUJ
Tue Aug 24, 2004 7:08 pm
It happened to me on a 737 in FS98 a few years back. I figured it was the speed and flaps in combination. However, no such luck with the 744 in FS9, I have occasions wher I struggle to take off in time (no crashes as of yet so I am fortunate in that way).
LHR27C
Tue Aug 24, 2004 9:48 pm
It happens to me occasionally, you should check the trim and make sure you lift off at VR rather than going too fast on the runway. Certainly a lot of flaps down will make a difference.
Once you have tasted flight, you will walk the earth with your eyes turned forever skyward
