justplanecrazy
Do You Use A FMC/S On Your Flight Sim?
Thu Aug 26, 2004 7:12 pm
Do you use a flight management computer or system for your flights on the sim.?
I used to on my PMDG 737 but got fed of with losing all the info i had put in when my pc crashed.Now i just put in the departure and destination a/p codes into the fmc to let me know how far i am away from my destination.
your pilots today on this 747 flight are captain oliver hardy and assisting will be FO stan laurel.Have a safe flight
timjohns
RE: Do You Use A FMC/S On Your Flight Sim?
Thu Aug 26, 2004 7:19 pm
I use the PSS MFDU on the A32X series which has 101 options, but is required for autolands. Also helps with navigation.
A.Net Airlines - 2 million miles!
WomBat151
Thu Aug 26, 2004 10:25 pm
I always use the FMC, because realism is very important to me.
Ian @ EHAM (AMS), 3,1NM of SPY VOR radial 205
Mir
Thu Aug 26, 2004 11:05 pm
Same here. I won't fly one without it (unless I'm in a GA mood). PSS Airbii and PMDG 737 are great.
srilankan_340
Thu Aug 26, 2004 11:23 pm
I have had trouble with them as well.
I use the trusty old FSNav. Works just as well for me.
People are often unreasonable, illogical and self- centered: Forgive them anyway - Mother Theresa
LHR27C
Fri Aug 27, 2004 5:21 am
I use FMCs/MCDUs all the time simply for the realism. Don't forget you can save at the least the routings so they can be recovered if your PC crashes. FSNav is alright but nothing like the real world.
Once you have tasted flight, you will walk the earth with your eyes turned forever skyward
FlyingColours
Fri Aug 27, 2004 5:26 am
I use the PMDG FMS, a damn fine one too. When I make my Flight Deck I'll be installing a proper FMS which will set me back about $450 US$.
I don't use one when I am on other aircraft because I don't have the PSS A32X or any for 74/5/6/7s
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
ZKSUJ
Fri Aug 27, 2004 6:39 am
Phil-What is your flight deck going to be like? How do you use and operate the FMC in the default 744?
FlyingColours
Fri Aug 27, 2004 7:03 am
I don't use an FMC on aircraft which don't have one, it makes flights a real pain in the butt though.
My flightdeck is going to be sweet. When I start it it will be just the captains side and the throttles + overhead (an Airbus A32X - since I could use any A318/9/20/21/30 with it), then when I move out I'll add the first officers side, I'll buy a working FMS for the captains side but not one for the F/O as I can't see the need in it yet. Then I'll add a proper frame to make the flight deck complete with F/D door and library. Hopefully I'll be able to go ahead with my extra plans which I keep under wraps  Big grin but it should be so damn cool and I could become an instructor too.
Phil
FlyingColours
Q330
Fri Aug 27, 2004 8:44 am
Wow, Phil, that sounds awesome! I'm coming over to your place!
I just got my FMC working on Eric Marciano's A320/330 panel, so from now on I'll almost always be using it.
-Q
Long live the A330!
