sevenheavy
PSS A320 Panel/POSKY A330. Compatible?
Fri Aug 27, 2004 9:32 pm
Whilst I'm in the mood for posting Smile, are the PSS A320 panel and the Posky A330 model compatible?. I have tried but the aircraft model seemed a little skittish at high altitude cruise and the autopilot had trouble holding decent cruise speeds. Should I be doing anything to the configs to smooth things over?.
Once again any info greatly appreciated.
SevenHeavy
So long 701, it was nice knowing you.
LHR27C
RE: PSS A320 Panel/POSKY A330. Compatible?
Sun Aug 29, 2004 4:58 am
It will be the POSKY flight dynamics more than the model that are causing the A320 autopilot problems, obviously being designed for a smaller aircraft it finds difficulty in coping with higher cruise speeds etc. Really you should buy the PSS A330 package, I don't know if they still have their sale but at one point it was only £7.50.
If you do want to keep with the A320 panel, I'd suggest maybe swapping the A330 flight dynamics (.AIR file in the main FS folder) with the A320's, although this might have some side effects...
Once you have tasted flight, you will walk the earth with your eyes turned forever skyward
SV777KiloAlpha
Mon Aug 30, 2004 2:49 pm
LHR27C,
What about using PSS330 or 340 panel with POSKY Model? Did anyone try it? Is there any problems with it?
 Big grin
SAT Sakhalin Airlines (Russian Federation)">HZ-AKA
PPL since 2006
LHR27C
Tue Sep 07, 2004 10:13 pm
SV777KiloAlpha
Many people have done this and it seems to work fine. At the moment I have the PSS A340 with the Aerodesigns model but I plan to swap to the POSKY model from what I hear about it.
