trijetfan1
02 A.c Mixed In With 04 Aircraft In Some File.....
Fri Sep 10, 2004 6:55 am
Hi all, im having a problem. When I download an a/c a lot of times it doesnt work because it is an 02 aircraft. Do you know of any sites that are free of 02 aircarft..... any help is apreciated.......And when I download a/c only about a 1/3 of them work. why is this?
Earned PPL June 26, 2007
MarBergi
RE: 02 A.c Mixed In With 04 Aircraft In Some File.....
Fri Sep 10, 2004 6:58 am
Where do you download your a/craft? I get mine from FlightSim.com and they have a FS2004 Forum which contains a/craft for fs2004. So far I haven't had a problem with anything I've downloaded.
Craigy
Fri Sep 10, 2004 7:14 am
Avsim have separate sections for 02 and 04 files too. When you are searching or browsing, select either FS2004 Original Aircraft or FS2002 Aircraft Repaints sections.
Craig.
KCmike
Fri Sep 10, 2004 8:06 am
The reason why only 1/3 of aircraft work is probably because they are textures only. Also sometimes the folder the aircraft is located in is deep within a bunch of folders and youll have to it.
Mike
Cleared for the option...
