mandargb
FS2K4 And Innsbruck Approach
Sat Oct 30, 2004 3:44 pm
I have tried number of times to approach into Innsbruck (LOWI)
Have the following experience
Say short flight from Munich to Innsbruck on a Fokker or A318 say.
On the approach ATC brings me down to 11 thousand feet and then clears for approach.
Usually it gets down to 11 thousand when I am like 7/8 miles out say from runway 8.
So from this height it is very hard to drop down to 3900 in reasonable distance to make it to runway 8.
I could never get down in last few attempts.
Other option is then is circle in the valley and then glide down to visual approach to 8 or from other other side 26.
Anybody has done this in FSIM.
Does anybody know how they do it in real life for approach in LOWI ?
Thank you in advance
ZKSUJ
RE: FS2K4 And Innsbruck Approach
Sat Oct 30, 2004 5:47 pm
I do visuals to practise my short final turns (Kai tak Styles) on runway 26 with a 744. This is so I can aim for the numbers and break in time. Very challenging.
phatfarmlines
Sun Oct 31, 2004 12:00 am
Depending on how the weather is, and what mood the AI air traffic controller is in, you can be vectored for a "Kai-Tak style" visual 2,000 ft. high or 11,000 ft. high. At FL110, you have no choice but to circle to descend. Similar situations can occur at airports surrounded by mountains such as ASE and KTM.
daumueller
Sun Oct 31, 2004 3:10 am
just check http://webapp.icnms.de/ben/nue-str-inn-muc/imagepages/image19.htm - it works, but you need a descend rate of up to -1800  Smile
cramos
Sun Oct 31, 2004 6:37 am
Mandargb:
Check out the following link, I think your answers are there:
http://www.flightsim.com/cgi/kds?$=main/howto/inns/inns.htm
Funny this topic came up because I've been thinking about trying out the approach since it's known for being difficult.
ZKSUJ
Sun Oct 31, 2004 5:22 pm
The approach is difficult, but you should get used to it after a while. Luckily on FS, there are no real passengers, or they would have really sore bums after being on my plane into INNS. Beinga a 744 pilot, you have to come down hard on the runway at INNS because it is a short runway and you need space to brake. No greasers for me an INNS  Big grin
