cramos
No Other Runways At Kdab
Tue Nov 02, 2004 3:51 am
For some reason at KDAB, there is only the option to take off from 25R/7L. There is a north/south runway but even if I put winds at exactly 360/180, I'll still get the east/west runway. Strangely enough, when I ask for another runway, my only choices are 7/25.
OB1504
RE: No Other Runways At Kdab
Tue Nov 02, 2004 4:51 am
Do you have FS9 or FS2002? In FS2002 they only use one runway; the longest one.
If it's FS9, well, I can't help you.
corey07850
Tue Nov 02, 2004 4:58 am
What kind of plane are you flying??? If you're in a 747 they'll give you 7L/25R regardless... if you're in a C-172, then I have no clue  Big grin
phatfarmlines
Tue Nov 02, 2004 9:57 am
There is a bug where certain crosswind runways will not activate for one reason or another. DAB is part of the bug unfortunately. The only way to fix it is by creating a runway star, but I wouldn't waste my time opening extra runways for sparse traffic in FS2004 (although it would contrast significantly from real-life operations at DAB).
cramos
Wed Nov 03, 2004 2:05 am
I'm using fs2004. I'll just take it the way it is. I was using a Fokker by the way. Although I think I also tried it with a C172. No worries. It's not the only place where I fly in fs2004. There's more airports out there.
portcolumbus
Wed Nov 03, 2004 3:16 am
Making a custom AFCAD wouldn't work?
cramos
Sun Nov 07, 2004 7:04 am
I've noticed more airports have this problem in Florida.
cramos
Sun Nov 07, 2004 7:03 pm
Could some one try something for me on their systems? Try going to KDAB and set winds to 000 or 180 and see what active you get. Also, try KOPF and set the winds to the same direction and see which active. As a third test, try KGNV and try and get the smaller runway active. It seems as though all Florida airports have a problem. I tried one in San Antonio and things worked fine.
