Delboy
Help On FS2002
Thu Nov 11, 2004 10:16 pm
I have just got a PC at home and have FS2002 installed. I have no manual and would like to ask the experts 2 questions.
1. Which keys do you use to steer the aircraft during taxying?
2. How do you advance the time of your flight should you wish to?
Thanks for reading, hope to hear some answers soon.
European
RE: Help On FS2002
Fri Nov 12, 2004 1:09 am
It is far easier,Nicer,Better to use a Joystick - you can get them from almost ANY computer shop, PC world will definitely have one!
1. Which keys do you use to steer the aircraft during taxiing?
You can set the keys to what ever you want them to do - just use one of the options when FS2002 is up on your screen - meddle about with all the settings like traffic rate - put on 100% if you have a good computer - the more percentage the more other planes on the ground and in the air - making you game more realistic!
Just don't land - LOL
If you are in a lesson or a flight that is all ready saved on the computer then I don't know - but click on select a flight and you can make what ever flight you want - from Heathrow to paris or Heathrow to New York - anywhere - and what every time,date,plane you want,
If you want to ask "ME" anymore info just click on my profile and send an instant message. OK!
Or just post another question - although u will get a quicker response from privet chat then in here with me.
European
Come on Ryanair! Come on BOH! BASE BASE BASE! Flying high in the skies...........
A3204eva
RE: Help On FS2002
Fri Nov 12, 2004 1:13 am
1. I really suggest the Sidewinder 2 joystick. I have it, and it's great Big grin
2. (on the menu in-flight)Options>Simulation time>(then select the speed)
I think it's in the Options, if it's the same as FS9.
A320
"They have lady pilots......... they're not that good, but they have 'em"
Delboy
RE: Help On FS2002
Fri Nov 12, 2004 2:05 am
Hi guys
I have a Logitech joystick but still can't figure out how to steer left and right whilst on the runway/taxiway. Probably being thicker than normal.
A3204eva..will try that later on.
Many thanks
European
RE: Help On FS2002
Fri Nov 12, 2004 2:56 am
Delboy,
Do not slant the joystick just turn it while level,
European
ZKSUJ
RE: Help On FS2002
Fri Nov 12, 2004 7:13 am
just go to settings and then assignments anbd configure the keys to what evere suits you.
Delboy
RE: Help On FS2002
Fri Nov 12, 2004 5:45 pm
Hi guys
Thanks for all your comments, it's gratifying to know that you still view beginners questions like mine with some sympathy.
My joystick doesn't 'twist', however, I managed to suss out that using keys 0 and Enter on the keypad (with numbers lock off) steers it left and right. I also managed my first full flight last night in a 777-300 from Heathrow to Manchester, nice greaser landing and stopped with just under half the runway left.
Thanks again guys.
ZKSUJ
RE: Help On FS2002
Fri Nov 12, 2004 5:53 pm
"Thanks for all your comments, it's gratifying to know that you still view beginners questions like mine with some sympathy."
We are all beginners in the form that we still learn stuff evry day  Big grin The day you syop learning is the day you die!!!
flymia
RE: Help On FS2002
Sat Nov 13, 2004 2:03 am
To make time pass press alt and go to the toll bar and go to options I think than simulation rate. If you joystick does not control the plane on the ground and since your joystick does not twist or you dont have rudder pedals you should go to realism options and check the box for auto rudder. Than the joystick will control the plane on the ground. Makes it alot better.
