Newark777
Can Someone Help Me With FS9
Tue Feb 15, 2005 5:52 am
I just began having problems with my FS9, but it only happens with the Kittyhawk 738. When I go in to change the payload, the game crashes when I click "OK." I don't think it has to do with my system specs, because it only happens with this one plane. I don't want to just delete it, because it is one of my favorite planes. If this has happened to anyone else, or you have an idea to why this is happening, any help is appreciated.
Harry
Very sad grounded 738 pilot.  Sad
MADtoCAE
RE: Can Someone Help Me With FS9
Tue Feb 15, 2005 6:07 am
Have you downloaded something for it recently? Like a panel, wingviews?
Operator!!! Give me the number for 911!!
Newark777
Tue Feb 15, 2005 6:34 am
No, I have left it untouched since the last time I have used it, and it worked fine before. I also hadn't installed the update, so that is not the problem either. I have installed the update since then to see if it helps, but it didn't.
Harry
clrd2go
Tue Feb 15, 2005 6:44 am
just for kicks..can you go into the kneeboard and scroll any of the pages without getting a crash?
If not (you do get a crash) read this string at flightsim.com and try the fix
contained therein
http://forums.flightsim.com/dcforum/DCForumID21/20636.html
Jim
What a long strange trip it's been
MADtoCAE
Tue Feb 15, 2005 6:45 am
Well, all I can think of is re-installing it.
Where did you get it? I want to see if it happens to me.
Newark777
Tue Feb 15, 2005 6:54 am
While you were typing, I went in and tried to do some troubleshooting on my own. I went in to the "aircraft" CFG file, and manually changed the hard-coded payloads to 0, so that I don't have to go into that window at all. It works fine now, so I guess it will be fine with that temporary fix.
Harry
MADtoCAE
Tue Feb 15, 2005 7:03 am
I'm glad you fixed it  Smile
Newark777
Tue Feb 15, 2005 8:59 am
Thanks for your help, I actually had that kneepad problem happen to me a while back. As for the plane, I got it off avsim.net, and it comes with a winglet version and a normal version. They also make a great 73G, which also comes with and without winglets.
Harry
