aerlingus330
Default GPS In Fs2002
Fri Mar 11, 2005 7:37 am
Hi, My question is- Is there any way of navagating with the default GPS system instead of using the FMC unit. In the PMDG 737NG
If there is how do you do it bring it up?
aerlingus330
Aer Lingus Airbus A330-300
msp753nwa
RE: Default GPS In Fs2002
Fri Mar 11, 2005 8:10 am
Hi, You can do two things. First you can use the "compass" display(The one that's next to the PFD. Sorry don't know the real word for it.) and press the APT button on the control panel above it. Or go in to for instance the default 737s panel.cfg go down until you see something like this
[Window02]
size_mm=456,378
window_size=0.5
position=8
BACKGROUND_COLOR=0,0,0
VISIBLE=0
ident=GPS_PANEL
gauge00=fs9gps!gps_500, 0,0
THIS ONE WILL NOT WORK IN FS2002 ,but it will work in 2004.
And put that in the PMDGs panel.cfg. If you do this you will have to go to VIEWS on the top menu , INSTRUMENT PANEL then click on GPS. And it should work.
Matt
Going Boeing
