pelican
Pmdg 737NG Problem - Help Needed!
Mon Apr 04, 2005 8:54 pm
Hi,
I've problem with my 737-700. If I increase the load (of my 737-700) I will always get the message - Aircraft not flyable CENTER OF GRAVITY not within limits! I've tried different loads but the result is always the same.
This is really annoying. I don't have the problem with my 737-600.
Any advice will be appreciated.
Thanks in advance,
pelican
justplanecrazy
RE: Pmdg 737NG Problem - Help Needed!
Tue Apr 05, 2005 12:14 am
In the ms9 fuel and weights just before you start your flight check the centre of gravity by looking at the black and white chequered part.it should be equal in your case it probably isnt.  Wow!
your pilots today on this 747 flight are captain oliver hardy and assisting will be FO stan laurel.Have a safe flight
RODOL
Tue Apr 05, 2005 7:16 pm
My problem with the PMDG pig is the auto-throttle not working. Sometimes it does, sometimes it doesn't. Anyone else have this trouble?
flymia
Tue Apr 05, 2005 11:35 pm
Well I never gotten the center of gravity message before.
For the A/T not working there could be alot of different reasons for that.
You have the center console autopilot controls on Normal and the A/T on. If you are using N1 you need to make sure the FMC is set. If just using the A/T and it is armed I dont know why I would not work.
justplanecrazy
Wed Apr 06, 2005 1:28 am
i think i know why the A/T is not working sometimes, theres a switch on the overhead panel ill find out whats its called and come back tomorrow and tell you.
AR1300
Wed Apr 06, 2005 2:26 am
Quoting Pelican (Thread starter):
Where did you get one from?
Mike.
You are now free to move about the cabin
flymia
Wed Apr 06, 2005 11:16 am
No switch on the overhead that I use for the A/T. Not sure of the name of the switch you are talking about since I never turn the radios off but it is on the top left corner of the over head, right? Thats the only switch I dont know on that overhead.
justplanecrazy
Thu Apr 07, 2005 1:50 am
Ive found that the auto throttle will not work if the 1 and 2 generators are not switched on.when you select auto throttle it just switches back off.So Rodol i wonder if this is your problem?  boggled
RODOL
Thu Apr 07, 2005 8:20 pm
Quoting Justplanecrazy (Reply 7):
Cheers JPC, I tried that and it worked! Just done AA Dallas FW-Houston with no problem a/t wise. Shame I ballsed up the landing! Getting cocky turning the ap off before I was over the numbers!!!  Wink
