Delboy
Canary Islands 2002/2004
Mon Apr 25, 2005 4:11 pm
I had this installed on my PC but had to remove FS2002 and all add ons because of problems.
I have just come to put all my software on again and can't do this one because I can't find the code that's needed to get the programme to run. Has anyone got this add on and could they please let me have the code?
Your help would be much appreciated.
Happy simming!!
apuneger
RE: Canary Islands 2002/2004
Tue Apr 26, 2005 12:31 am
If you're having a problem with a certain FS Addon, just contact the manufacturer. If you explain them your problem, they might give you a new one, or explain to you how you might get everything back up and running
Don't expect us (well, at least me...) to give you a serial or reg key because you 'have lost yours'... Most codes are strictly personal and hence it is not allowed to give it to others. Just asking here for a code of some payware is...well...something you don't do.
Ivan
Ivan Coninx - Brussels Aviation Photography
Delboy
Tue Apr 26, 2005 12:47 am
Apu
Thanks for the answer didn't feel the need for the second paragraph though, do the software secret police come and kick the ***t out of you, if you do this? I now know why I use this site less and less!
I am not asking for your bank details, however, I will contact the manufacturer as you suggested.
BMIFlyer
Tue Apr 26, 2005 3:13 am
Quoting Delboy (Thread starter):
Did the manufacturer not send you an email with the Code?
I keep copies of all my payware add-on "codes" on disk, just in case I have to re-install for any reason.
May I suggest you do the same in future?
Lee
Delboy
Tue Apr 26, 2005 3:59 am
Thanks Lee
It was on a sticker inside the case which has got mislaid, I do take your point though and will make a note in future.
By the way, I also posted this question on a proper simmers website and got the answer back within the hour, just goes to show you doesn't it!!
