LHB727230Adv
FS2004 Learjet ATC Problems
Thu May 12, 2005 11:18 am
Hi to all of you FS professionals. Every time I vacate the runway and contact ground on ATC mode the game crashes and quits. It has only happened on the Learjet. Has anybody else experienced this problem? If yes, how do you fix it? Any replies greatly appreciated.
BTW, I've already done a search for this and found nothing.
Alex  bigthumbsup
apuneger
RE: FS2004 Learjet ATC Problems
Thu May 12, 2005 7:46 pm
Are you sure it doesn't happen on the other default FS2004 aircraft. An option could be to reinstall FS2004 or only the Learjet aircraft (if this is possible). Could be related to one of the aircraft files, or somewhere in FS2004 there could be an error where she interacts with the Learjet.
Anyway, I haven't had the same problem. Hope you manage to fix it however!
Ivan
Ivan Coninx - Brussels Aviation Photography
LHB727230Adv
Fri May 13, 2005 10:23 am
Thanks anyway Ivan, I'll try with some other aircraft and maybe reinstall, but first I have to see if I can fix it more easily.
Alex  bigthumbsup
