Pe@rson
Running FS2002 While Doing Other Things
Fri May 20, 2005 8:36 pm
A basic question for you. How can I enable FS2002 to run while I am doing other things, i.e. on the Internet?
Cheers.
futureuapilot
RE: Running FS2002 While Doing Other Things
Fri May 20, 2005 8:56 pm
I just have another computer sitting next to my FS computer. I also can't run more than one program without the sim pausing.
-Sam
The Pilot is the highest form of life on Earth!
Gerry
If you mean that it stops when you go on to something else try going to the options menu and then "settings - General" and then deselecting
'pause on task switch". That should fix it.
justplanecrazy
Thu May 26, 2005 10:14 am
Gerry's right thats what you have to do.I do it all the time.
your pilots today on this 747 flight are captain oliver hardy and assisting will be FO stan laurel.Have a safe flight
Eduardo Lepe
Thu May 26, 2005 12:24 pm
Also a good tip during running other applications,
FS normally is at full screen, if you want to be on Windows with the FS label in the Start Bar. Simple, once you are on the FS press ALT + ENTER at the same time, it will resize the FS window and you will be able to see your applications.
The unpause option is another good solution:D
Best Regards!!! Eduardo Lepe.
trekster
Thu May 26, 2005 5:47 pm
was gonna say the exact same thing
Where does the time go???
