CcrlR
FS98 On WindowsXP?
Fri Jun 03, 2005 12:32 pm
I wanted to know if anyone here still uses Flight Simulator 98 on Windows XP? What about the dowloaded planes and scenery, do they work or will they if you use Windows XP? I just wanted to know (I don't want no blasting about getting FS2000 or any higher version of the flight sim).
"He was right, it is a screaming metal deathtrap!"-Cosmo (from the Fairly Oddparents)
komododx
RE: FS98 On WindowsXP?
Fri Jun 03, 2005 12:51 pm
Yes it does! I recently found my burnt illegal copy of FS and run it on XP.
Stefano  wave
I'm homeless and unemployed
trekster
Fri Jun 03, 2005 5:23 pm
I dont think i could play 98 now, im used to ATC, and gps, and could VR Cockpits, i played 95 last year, and thought, MY GOD, look how far we have come
Where does the time go???
dc-10 levo
Fri Jun 03, 2005 9:24 pm
I don't use FS98 anymore, but Windows XP has somthing called "Compatibility Mode" where you can choose which operating system you want to run the program on. If you right click the FS98 icon, go down to and click "Properties", click the "Compatibility" tab at the top of the pop-up screen and then check the check box where it says "Run this program in compatibility mode for: ". You'll then get the options of which operating system you want to run FS98 on.
DC-10
