UtilianPilot07
Downloading/ Installing Posky 757
Tue Jun 07, 2005 6:29 am
Hello,
I have tried many times to successfully add the Posky American Airlines 757, but failed. Do you know what I am doing wrong or what I need to do?
Here is Some of my problems:
1. I Downloaded the Virtual Cockpit and added the VC to the Model File and it does not work.
2. The 757 uses the sound that I believe is the Cessna 172 or Beech Baron.
These are the two more noticeable problems I have encountered.
Any Information will be greatly appreciated.
The Bin 3 Tight Stack!!
N754AN
RE: Downloading/ Installing Posky 757
Tue Jun 07, 2005 7:19 am
Hi,
Quoting UtilianPilot07 (Thread starter):
I think you are meant to put the VC into the panel folder.
That sound comes as default with most aircraft downloads. You have to download the seperate sounds for the 757 and then put them in your 757 folder.
Hope this helps,
Chris  wave
Fankoooooooo
eclipseflight7
Tue Jun 07, 2005 7:30 am
The plane is intended for use with an addon sound set, but if you want to just hear the default sounds then open your sound.cfg in the aircraft folder and replace whatever is in there with this:
[fltsim]
alias=b737_400sound
As for the VC, it is imparitive that you have the VC model in your aircraft folder, no where else. It should say something like model.VC. Open up your aircraft.cfg and find the entry for the plane you want to put the VC on. Where it says Model= put VC on the end of it so you get Model=VC.
If that doesn't work, tell me to what stage you can get the plane to load, IE; can you open it in the menu or does it crash when you finally get into the FS world.
Holy sh*ts and burritos.
ACDC8
Tue Jun 07, 2005 7:53 am
I downloaded the Posky 757 (DHL) a few weeks ago and got everything to work fine. I did pretty much what Eclipse did. But for some reason the weight & balance is totally messed up. No matter what I do I always have a too forward C of G, I can't get it behind the red line. Any ideas?
A Grumpy German Is A Sauerkraut
UtilianPilot07
Wed Jun 08, 2005 3:29 am
Quoting EclipseFlight7 (Reply 2):
I can select it in the menu and fly it, the only problem is the sound and the virtual cockpit.
Gofly
Wed Jun 08, 2005 3:35 am
Quoting UtilianPilot07 (Reply 4):
In the sound folder, there should be a file named "sound.cfg" delete it.
If you want the default sound, open up your default 777 folder (777-200) or something similar.
Go in to the sound folder in that, and find the "sound.cfg" copy and paste that into your 757 sound folder.
Sorry if that isn't very clear!  Smile
Living the high life on my ex-Airliners.net Moderator pension...
