N754AN
GPS Map
Sun Jun 19, 2005 5:39 pm
Hi all,
I downloaded a 757/767 panel recently which is great but I have one complaint!
The GPS Map that comes with the panel is a 295, which is of a different layout to the standard one.
Does anybody know how to change it to the standard GPS Map? or even if it is possible?
Chris
Fankoooooooo
tbanger
RE: GPS Map
Sun Jun 19, 2005 5:52 pm
You will need to go into your panel.cfg file and open it up using word or any text editor.
What you will see is something similar to:
[WindowXX]
Background_color=0,0,0
size_mm=512
window_size_ratio=1.00
position=0
visible=0
ident=30
window_size= 0.500, 0.500
window_pos= 0.000, 0.000
gauge00=gps!gps, 2,3,300,500
What you need to do is replace this section with this:
[WindowXX]
size_mm=456,378
window_size=0.5
position=8
BACKGROUND_COLOR=0,0,0
VISIBLE=0
ident=GPS_PANEL
gauge00=fs9gps!gps_500, 0,0
This should do it for you.
N754AN
RE: GPS Map
Mon Jun 20, 2005 2:08 am
Thanks for your help Tbanger,
It worked a treat!
I discovered that the panel in question was also missing a radio stack!.. So i used my brains for once and did the same thing as above, taking the information from a 777's panel .cfg and hey presto...it worked!
Thanks once again
Chris  wave
Fankoooooooo
