ZSOFN
Help! Southern Europe Default Scenery For FS2004
Tue Jul 05, 2005 7:58 am
I've been trying to solve this one for a while now...
For some reason many of the airports that come as standard in FS2004 are no longer appearing. When I go to the airport all the facility data is there i.e. what you alter in AFCAD but none of the buildings, runways, taxiways or aprons appear, not even taxiway/runway signs. The AI aircraft appear in what would be the correct positions.
I've been told it might be to do with addon scenery that over-wrote some of the stock files (...sceneryeurwscenery) but I'm not sure that's the case because I have restored all the original files in that folder from the FS CD.
I'm completely stumped, what can I do???
 Confused
dogfighter2111
RE: Help! Southern Europe Default Scenery For FS2004
Wed Jul 06, 2005 2:30 am
Hi,
Ok, i can really only give you 2 pieces of advice.
1. Start FS, then go to 'Settings'
2. Click on 'Display' and then on the the first panel make sure your settings look like this:
The other option:
2. Now click on 'Scenery Library' and look down the list until you see 'Western Europe' and then click on that name.
3. Now click on 'Move Up' and keep clicking until it is BELOW any other EU scenery (Other than the one you are trying to overwrite)
4. Now look for 'Eastern Europe' and click on that name.
5. And again, click on 'Move Up' until it is BELOW 'Western Europe'.
That should be it. Please tell me if it works.
If not, tell me your computer specs and i'll try to help you more.
Mike
ZSOFN
Wed Jul 06, 2005 2:34 am
Thanks Mike, I'll give that a go now...
edit: I discussed this here:
http://www.flightsimmer.com/forums/showthread.php?t=39634
Just so you can see what's already been tried...
Tom
dogfighter2111
Wed Jul 06, 2005 2:41 am
Ok, please reply here and tell me if it works or doesn't.
I had a similar problem with some UK scenery and the only way i sorted that was Re-Installing FS2004. But, if you do that copy your aircraft, gauges and effects folders from the FS folder and then delete the whole FS9 folder.
Mike
ZSOFN
Wed Jul 06, 2005 6:07 am
Cheers Mike
I'm really short of time at the moment so hopefully within the next couple of days I'll be able to reinstall FS. I think you're right, it's the only option I have left!
Tom
dogfighter2111
Wed Jul 06, 2005 6:09 am
It is a shame, but remember to save all downloaded aircraft and the gauges folder.
Mike
P.S. MSG me the outcome our just post here. Good Luck!!!
ZSOFN
Sat Jul 09, 2005 3:37 am
Haven't had time to do the reinstall yet, maybe tomorrow as it's saturday.
BTW, I've posted some screenshots of the problem in this forum:
http://www.flightsimmer.com/forums/showthread.php?t=39634&page=2
ZSOFN
Fri Aug 19, 2005 11:00 pm
This thread may be long dead by now but it might be of some use to people out there. The problem was addon scenery for Dubrovnik (LDDU) that contained an old form of exclude file with an error in it that wiped out most of my southern European airfields.
I downloaded a patch for the scenery and all's fine now.
David L
Sat Aug 20, 2005 1:02 am
Quoting ZSOFN (Reply 7):
Wow. They tested that well!
