aerlingus330
Avsim Problem.
Sat Jul 30, 2005 9:56 am
Hi,
I have a problem with Avsim...When I download an aircraft, at the end of the download...I get a message saying " This file is either corrupt or invalid" and appears not to have downloaded.
Has anyone else had this problem?
Is it fixable, and how?
Thank-You,
AerLingus330
Aer Lingus Airbus A330-300
jeffry747
RE: Avsim Problem.
Sat Jul 30, 2005 4:52 pm
The other day I couldnt get anything from ANY freeware sight. I kept getting a little window saying there was no data in the download, and the download would not go through.
C'mon Big B, FLY!
SA006
RE: Avsim Problem.
Sat Jul 30, 2005 5:34 pm
AerLingus.
Try opening the compressed zip folder by right clicking it then "Open With" then "Compressed (zipped) Folders"
Should work.
-SA006
Proudly South African
aerlingus330
RE: Avsim Problem.
Sat Jul 30, 2005 9:37 pm
It dosent get to open the file...all it says is " The compressed zipped folder is corrupt or invaled"
AerLingus330
OB1504
RE: Avsim Problem.
Sun Jul 31, 2005 12:31 am
Quoting SA006 (Reply 2):
Isn't that just for Firefox users? I've never seen that on Internet Explorer (back when I used it), but I have on Firefox.
SA006
RE: Avsim Problem.
Sun Jul 31, 2005 1:03 am
I had to do that on my old computer and I was using IE.
-SA006
aerlingus330
RE: Avsim Problem.
Sun Jul 31, 2005 6:12 am
I read the help file on avsim and it said to click Save on the Download Dialog instead of Open...
So, I have another problem, when I click Download on Avsim...It just automatically downloads and the Download Dialog does not show up, So it must be set to open instead of save, to give me the corrupt message. So I have to acess the dialog to change it...
Does anyone know how to access it manually to change the setting to save?
Thank-You  Smile
AerLingus330
airlinelover
RE: Avsim Problem.
Sun Jul 31, 2005 7:20 am
I use Firefox, NS, or IE depending on the comp I am using..
It works fine
Chris
Lets do some sexy math. We add you, subtract your clothes, divide your legs and multiply
Ready4Pushback
RE: Avsim Problem.
Tue Aug 02, 2005 11:31 pm
Quoting Aerlingus330 (Reply 3):
I have had this problem before. I eventually download winzip, which doesn't seem to have so many problems reading the zip files.
I think there is also a link to the file on the download page. Try right-clicking the link and selecting "save target as" and find a location for the file yourself rather than letting IE just download it. I have found that this helps getting rid of that error.
BMIFlyer
RE: Avsim Problem.
Fri Aug 05, 2005 1:41 am
Quoting Aerlingus330 (Reply 6):
Hi, on your browser menu bar (up top) Click as follows.....
Tools
Internet Options
Select 'Security' then 'Custom Level'
Scroll down to the section marked 'Downloads' and make sure the 'Automatic Prompting For File Downloads' is marked as Enable.
Close the browser then try to download a file from Avsim again.
That should hopefully have solved your problem  Smile
Lee
aerlingus330
RE: Avsim Problem.
Fri Aug 12, 2005 2:35 am
Thanks for your replys guys...
BMIFlyer, your idea worked thank-you.
AerLingus330
BMIFlyer
RE: Avsim Problem.
Fri Aug 12, 2005 5:15 am
Quoting Aerlingus330 (Reply 10):
No problem  Smile
Lee
