AADFWCrewChief
Flight Sim 2004 Question
Tue Aug 02, 2005 12:57 am
Hello Folks,
Just bought Flight Sim 2004 and tried to add new aircraft...I can downlaod them and extract the files but nothing shows up in the sim and I can't figure out how to get to the aircraft editor?
Any Help would be great
Ray
dogfighter2111
RE: Flight Sim 2004 Question
Tue Aug 02, 2005 2:16 am
There is no aircraft editor in FS 2004.
You must make sure you unzip the files to a temporary folder, then open the first folder and copy the second folder into
C:Program FilesMicrosoft GamesFlight Simulator 9Aircraft
If there is more than 1 folder in the first folder, then just copy the first folder into C:Program FilesMicrosoft GamesFlight Simulator 9Aircraft.
Mike
David L
Tue Aug 02, 2005 4:04 am
If more is involved than just an aircraft folder, there should be a text file with installation instructions. As DogFighter2111 says, unless you know exactly what the structure of the zipped file is, unzip it to a temporary folder and see if there's a text file with instructions. Winzip extracts to C:/Unzipped/-filename-/ by default. E.g. a file called Artichoke.zip would be extracted to the folder C:/Unzipped/Artichoke/ which Winzip will create (replace the slashes with backslashes - I can't get them to appear in the post).
flymia
Tue Aug 02, 2005 11:04 am
You should Copy and paste the files in the folders they need to go to. extratcing them using the wizard does not always work.
David L
Tue Aug 02, 2005 6:16 pm
Quoting FlyMIA (Reply 3):
You mean extracting directly from the zip file into the FS folders? Yes, definitely better to extract to a temporary folder first.
PA110
Sun Aug 07, 2005 5:04 am
Hi folks, I have another question... I've downloaded quite a few AI files and they are working just fine. But, how do I get rid of the fictional airlines/traffic generated by FS2004?
It's been swell, but the swelling has gone down.
