MADtoCAE
Squawk Box 3 Problems...
Tue Aug 09, 2005 10:08 am
Hello all,
For users of SB3...
When I start the flight and go to the modules thing the "Start Squawk Box" isnt there.
Anybody know whats wrong or how I can fix it?
Operator!!! Give me the number for 911!!
OV735
RE: Squawk Box 3 Problems...
Sun Aug 14, 2005 3:52 pm
Do you have FSUIPC installed and registered for use with SB3? If not, it probably won't work.
oxidesigns
Fri Aug 19, 2005 9:28 pm
Try again, it doesn't appear there sometimes. And It will not appear when you start FS after not closing SB3 in a previous session. All you would do to cure it is, close FS and start it over again. Even then it may not load sometimes.
Check for the .DLL files in the Flight simulator 9Modules folder
There should be 3 all named similarly sb....9.dll
